Home > General Chat > does anyone remember the gearset
Does anyone remember the gearset that was more well suited for a long final drive and turbo application, if i remember correctly it had quite a short first gear and well spread ratios, i have been searching for about half an hour to find the post but cant, can anyone help??
i think you mean the minispares clubman set this has a shorter 1st than the ST set
I have the tran x ST set in mine and will be going from a 3.44 to a 3.2 on the rebuild as i dont see the long first as an issue
Edited by wolfie on 10th May, 2011.
Nicked from guessworks
2.583 1.711 1.250 1.000 Minispares (Clubman ratios CR/SC) C-STN39
2.544 1.731 1.258 1.000 Minispares (Abingdon ST ratios CR/SC) C-STN77
2.313 1.567 1.187 1.000 Minispares (Metro Challenge CR/SC) nla?
2.544 1.731 1.258 1.000 Minisport (Abingdon ST ratios CR/SC) GRBMS4014
2.544 1.731 1.258 1.000 TRAN-X (Abingdon ST ratios CR/SC)
2.583 1.711 1.250 1.000 TRAN-X (Clubman ratios CR/SC)
No not the clubman set i belive it was done by jk or quaife or something, i really cant remember but someone on here had the gearset.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Think you probably mean this quaife set:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=322298
Looking forward to seeing how it performs in mine.
Asphalt
Member #: 1027
Germini, black forrest
http://www.quaife.co.uk/shop/products/qke5a
http://www.quaife.co.uk/shop/products/qke8a
http://www.quaife.co.uk/shop/products/qke3a
:) Too bad I can't afford one, they look interessting :)
[X] nail here for new monitor
