| Home > Help Needed / General Tech Chat > Engine splutters when on boost and is spitting back into the carb | |||||||
![]() 163 Posts Member #: 9181 Advanced Member Rhoose, Cardiff |
23rd May, 2011 at 07:28:58pm
Hi everyone
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
23rd May, 2011 at 07:33:17pm
Id suggest you take it to a rolling road and have it setup by someone. It might cost you 100 quid but itll save you money in the long run.
23rd May, 2011 at 07:36:00pm
Yeah ive got it booked in at minispeed for next week but i want the car to drive well enough for me to get it there. My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
23rd May, 2011 at 08:01:45pm
Do you have any oil in dash pot? Has it ever run ok? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
23rd May, 2011 at 08:08:50pm
have you checked timing??? Done now needs redoing lol |
23rd May, 2011 at 08:19:05pm
yeah theres oil in the dashpot and its fitted with megajolt and currently running the standard metro turbo ignition map.
23rd May, 2011 at 08:21:39pm
you could change the rockers bk Done now needs redoing lol |
23rd May, 2011 at 10:10:41pm
ive had that a few times when fettling needles, wb02 always said lean and more fuel cured it
Edited by Brett on 23rd May, 2011. Yes i moved to the darkside |
1300 Posts Member #: 829 Post Whore essex |
23rd May, 2011 at 11:13:04pm
On 23rd May, 2011 adamt said: have you checked the oil in the top of the dash pot ?
Hi everyone I recently fitted a new engine and i did post a thread about the engine smoking which i found out was because the valve stem seals kept lifting up. However i have another problem. The engine is spluttering when on boost and sometimes the boost spikes. It also hesitates when trying to rev it from idle and spits back into the carb. I thought it was a fueling issue and have just fitted a brand new regulator but that isnt the problem. I have also tried different mixture settings. Or could it be something to do with the turbo and boost/vacumm hoses. Any ideas? Thanks Adam 1293 Turbo mini
24th May, 2011 at 07:05:54am
When you changed the rockers did you drain the water??
24th May, 2011 at 10:20:53am
My money is on it being weak mixture, possibly made worse by wrong/insufficient oil in the dashpot. |
24th May, 2011 at 08:35:15pm
lean mixture. Ive got the same problem atm at a certain throttle point. How did u stop ur stem seals pushing up? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
25th May, 2011 at 09:21:40am
I kept pushing them back down with a screwdriver but within 2 minutes of running they were back up again. So i changed all the seals by making this tool that levered off the head studs and compressed the valve springs. The only thing is i had to fill the bore with string to stop the valve dropping down (i was too lazy to take the head off) I also changed the rockers as well from some high lift ones to some 1.3s and now its stopped smoking completely. but i have looked again and one has pushed back up! so its staying there for the moment. My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
25th May, 2011 at 12:47:27pm
i was thinking of doing the same as its a basterd to take head off. So did u push a roll of string then push the piston up to the valves? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
25th May, 2011 at 03:23:32pm
25th May, 2011 at 10:36:04pm
yeah you just have to keep feeding the ball of string in, it does take a lot. I moved the piston up first and used a screwdriver to pack it in tight. My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
150 Posts Member #: 8909 Advanced Member North Cornwall |
25th May, 2011 at 10:48:14pm
Lil tip me and dad made an adaptor out of a old spark plug with a male air line connector and used air pressure in the cylinder to hold the valve up, worked a treat! If in doubt... flat out! The words of a true legend |
26th May, 2011 at 10:58:26am
gd idea ben. Il try 1 of those. Anything to avoid taking the head off 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
26th May, 2011 at 11:19:10am
Worst case if you drop a valve head off. If something is worth doing, it's worth doing half of. |
