| Home > Help Needed / General Tech Chat > Front end weight | |||||||
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
20th Jul, 2011 at 06:55:15pm
Im thinking of doing a fibreglass/carbon front end to save weight. Just wondered if anybody has bothered to weight a standard front end and a fibreglass one to see what difference it makes?
20th Jul, 2011 at 07:23:05pm
ive got an all steel bolt on front end, ill try weigh it next time i got chance Yes i moved to the darkside |
20th Jul, 2011 at 08:23:52pm
It should be in here somewhere.
20th Jul, 2011 at 08:37:42pm
Thanks brett and thanks matty. I look on the search for about a hour and couldn't find what i was looking for. Edited by Chris Dillow on 20th Jul, 2011. |
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
20th Jul, 2011 at 08:54:38pm
My 1 piece fibre glass front weights 14kg with mk1 grill and headlamps. Brace bars 2.5kg each. Class C 3rd Place Avon 2011 14.18 @101mph |
20th Jul, 2011 at 08:59:11pm
Where is your one from alakanow ??
20th Jul, 2011 at 09:16:33pm
Abs, not bad quality, but alot of work to get a good fit. You have alot of cutting to do. I'd also recommend fitting it with a engine in place. Mine sits lower than steel bonnet line and just clears rad. Matt Class C 3rd Place Avon 2011 14.18 @101mph |
21st Jul, 2011 at 03:13:06pm
I'm personally of the opinion that unless your front end is rusty leave it, Your car looks nice and subtle.
21st Jul, 2011 at 04:31:37pm
My heavy duty 2 piece fg front + brace bars, from arc angels, weighs still significantly less than my old steel roundnose i cut off. But if youre fussy about panel gaps and fitment id forget about it, they're a complete and utter arse to fit, although i imagine it may be easier retaining steel a panels, i went for fg. On 26th Jan, 2012 Tom Fenton said:
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
21st Jul, 2011 at 07:57:50pm
Well according to mini mag, which is more or less a TM special with johns gold twink turbo on the front, there are some weight saving tables, they say a std steel front end inc bonnet is 15.5kg and a carbon one is 2.5kg!!(sounds a bit on the light side to me that!) a saving of 13kg, just a bonnet is 5.5kg steel and 1.2 carbon. its issue 170, a handy issue for the weight concious amongst you :) |
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
21st Jul, 2011 at 09:10:57pm
Read that issue it is very good. goes from the nice easy weight removing techniques such as removing the rear seats to full on all guns blazing how deep are your pockets weight removing. The turbo build has finally started |
21st Jul, 2011 at 09:51:11pm
I am concerned about how it looks. I think i want the impossible and make it so you cant tell that its a plastic front end.
