Page: |
Home > FAQ / Knowledge > Building an RTS clutch - Photo Heavy | |||||||
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
4th Apr, 2013 at 11:06:18pm
Nice guide mate, you can not beat guides with step by step pictures, Thanks will be using this for sure at some time in the future.. Alan Main Build
5th Apr, 2013 at 08:20:47am
Been reading this guide and have a question around this statement:
On 14th Aug, 2011 almichie said:
The new spacers need to be the length of the originals plus the thickness of the additional spring. Surely that can't be right. If, for example, you are using 2 x 2mm springs. If you make the new spacers 2mm longer than the originals it will push the outer spring 4mm towards the wok (2mm spring plus 2mm extra n the spacers). In my mind, this knocks the whole lot out of alignment and is possibly the cause of the heavy pedal in some peoples cars. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
5th Apr, 2013 at 08:56:26am
What would be good is a side view of the assembly so you could see the setup better.. Main Build
5th Apr, 2013 at 09:16:57am
Pic's here:
313 Posts Member #: 9367 Senior Member Derby |
5th Apr, 2013 at 09:18:54am
That is quite possibly the case. Surely all you're doing is still spacing to the underside of the spring which will be in the same position as usual therefore a standard size spacer would acheive the same thing.
On 5th Apr, 2013 apbellamy said:
Been reading this guide and have a question around this statement: On 14th Aug, 2011 almichie said:
The new spacers need to be the length of the originals plus the thickness of the additional spring. Surely that can't be right. If, for example, you are using 2 x 2mm springs. If you make the new spacers 2mm longer than the originals it will push the outer spring 4mm towards the wok (2mm spring plus 2mm extra n the spacers). In my mind, this knocks the whole lot out of alignment and is possibly the cause of the heavy pedal in some peoples cars. |
5th Apr, 2013 at 09:34:44am
In my mind it makes more sense to take the spacers smaller by the thickness of the additional spring to make sure it's external dimensions are the same as an unmodified unit. On 11th Feb, 2015 robert said:
![]() 12303 Posts Member #: 565 Carlos Fandango Burnham-on-Crouch, Essex |
5th Apr, 2013 at 10:02:41am
andy, if you do that it wont fit together. or rather it will but the spacers will flap about as it bottoms out on the springs.
5th Apr, 2013 at 10:13:13am
So roughly what thickness ideally should they be. I understand they all vary. And what ID and OD? |
5th Apr, 2013 at 10:20:48am
Got ya. I was thinking the spacer supported the spring, rather than the bolt/rivet.
5th Apr, 2013 at 10:24:14am
ID M8 clearance, OD 11mm,
![]() 10015 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
5th Apr, 2013 at 10:57:47am
Yeah the ones we got from you Joe we had to trim them down for the van's RTS. That was with 2 x 998 AP spings. If something is worth doing, it's worth doing half of. |
5th Apr, 2013 at 11:24:56am
So can we say that you make the spaces to suit each individual clutch you take apart.. Main Build
5th Apr, 2013 at 12:10:11pm
Sounds that way. |
5th Apr, 2013 at 12:35:17pm
Yep,
7th Apr, 2013 at 07:57:35pm
Can anyone recommend a torque setting for the bolts shown in joes sketch above?
7th Apr, 2013 at 08:06:20pm
FT aka F**kin Tight? If something is worth doing, it's worth doing half of. |
7th Apr, 2013 at 08:13:16pm
LOL
![]() 9500 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
7th Apr, 2013 at 08:17:36pm
not more than about 25 ftlbs, i settled on about 18 on mine ( after stripping a thread and starting again) Yes i moved to the darkside |
7th Apr, 2013 at 08:25:19pm
yeah, the fly wheels is pants metal and not that thick, I'd agree with the above.
7th Apr, 2013 at 09:13:02pm
7th Apr, 2013 at 09:20:06pm
prooving the point of poor engineering practices Brett, it's not directed at you personally, it is merely you have experienced why it is poor engineering ![]() Edited by Sprocket on 7th Apr, 2013. On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2013 at 09:23:45pm
Also, as the spacer is only thin walled you could crush it if you wang it up fooking tight. On 28th Aug, 2011 Kean said:
7th Apr, 2013 at 09:24:55pm
On 7th Apr, 2013 Joe C said:
Also, as the spacer is only thin walled you could crush it if you wang it up fooking tight. if you can get it that tight without stripping the thread ![]() On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2013 at 09:27:03pm
7th Apr, 2013 at 10:06:14pm
prooving the point of poor engineering practices Brett, it's not directed at you personally, it is merely you have experienced why it is poor engineering ![]() poor engineering practices, as in taping a thread into what is essentially sheet steel where the thickness must be as small as 1/3 the diameter the hole i agree totally, the method you came up with obviously gets round this but is not 100% necessary imo this particular one pulled through just whilst nipping it up and it did give me the opportunity to 'test' what torque they pull through at 25ftlbs ish feels more than tight enough, infact 18flbs ish has been tight enough so far Yes i moved to the darkside |
Page: |
