| Home > Help Needed / General Tech Chat > My diff locks up when torqued down | |||||||
17th Sep, 2011 at 03:20:00pm
17th Sep, 2011 at 03:22:50pm
Is the body of the diff fowling the case somewhere? Tbh I dont know the atb to give any good advice I seriously doubt it! |
17th Sep, 2011 at 03:24:50pm
No mate i was thinking that at first. I have started posting on Instagram also my name on there is turbomk1golf
17th Sep, 2011 at 03:26:27pm
You usually have to have the case machined to fit an LSD. I know I did...
Edited by jamie@thefatgarage on 17th Sep, 2011. |
17th Sep, 2011 at 03:28:51pm
I have fitted it as per this mate.
Edited by madmk1 on 17th Sep, 2011. I have started posting on Instagram also my name on there is turbomk1golf
17th Sep, 2011 at 03:30:18pm
simon , is this locking up immediately the moment you bolt the rear casing to the gearbox ,or only after you do the last 1/4 turn of the bolts , or its fine bolted up ,but then when you put on the side covers it wont move ..?how much gaskets does it need to work , is it fouling on the back cover cos its a lsd and bigger in the body ?
17th Sep, 2011 at 03:38:25pm
Ok doc!
17th Sep, 2011 at 03:46:53pm
The casings that use studs/nuts to hold the diff housing on (casting number DAM2886) require the gaskets.
Edited by Rod S on 17th Sep, 2011. Schrödinger's cat - so which one am I ??? |
17th Sep, 2011 at 03:50:36pm
Well i have a Dam5626 with studs lol. I have started posting on Instagram also my name on there is turbomk1golf
17th Sep, 2011 at 03:52:09pm
On 17th Sep, 2011 madmk1 said:
Well i have a Dam5626 with studs lol. See my edit above. Schrödinger's cat - so which one am I ??? |
17th Sep, 2011 at 04:47:55pm
measure the ovality of the diff bearing housings with the rear case bolted up tight without gaskets or the diff installed. Use a bore gauge. The hole should be near as damn it round. If its not, measure it again but this time fit gaskets. If its still not round, the rear housing might be a miss match perhaps. On 26th Oct, 2004 TurboDave16v said:
1425 Posts Member #: 690 Post Whore Norfolk |
17th Sep, 2011 at 04:49:57pm
All the atb's I've fitted have needed the rear case dressed to miss the edge of the diff case on one of the "bosses" which holds the thread for the side plate, obviously this is the opposite end to the crown wheel, it's not much, but enough to lock the diff
If Carling made Mini engines
17th Sep, 2011 at 04:55:16pm
I would get a marker pen and colour in the inside of the diff cover then fit it and tighten to just before it totally locks up, then rotate the diff and remove the cover. See if any of the marker pen has rubbed off. I seriously doubt it! |
17th Sep, 2011 at 05:01:16pm
also make sure you shim it the right side (flywheel side) otherwise you might find the crownwheel locks up on the pinion bearing. On 28th Aug, 2011 Kean said:
17th Sep, 2011 at 05:31:37pm
On 17th Sep, 2011 johnK said:
All the atb's I've fitted have needed the rear case dressed to miss the edge of the diff case on one of the "bosses" which holds the thread for the side plate, obviously this is the opposite end to the crown wheel, it's not much, but enough to lock the diff Jk Ok i have found it :) John your bang on mate. I will post some pics when i come in from the shead for all to see. I have started posting on Instagram also my name on there is turbomk1golf
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
17th Sep, 2011 at 05:49:35pm
My atb fitted fine with no problems. Simon where did you buy yours from? |
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
17th Sep, 2011 at 08:43:04pm
I had the same problem, turned out to be same thread boss. Class C 3rd Place Avon 2011 14.18 @101mph |
17th Sep, 2011 at 09:09:37pm
We had the same problem. I had to relieve the inside of the diff casing as well, not just the boss. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Sep, 2011 at 09:48:35pm
Some pics of what i had to do to get it working.
18th Sep, 2011 at 10:30:48am
Good stuff If Carling made Mini engines
