| Home > Introduce Yourself > Turbo Sprite - now joined up to TM | |||||||
29 Posts Member #: 9668 Member Nuneaton |
5th Nov, 2011 at 09:13:52am
Hi - been looking on TM's for a while - although I have been running my Sprite with a turbo for over 18 years. When I first put it together, of course there were no forums, and I had to figure it all out myself - albeit with some inspiration from Vizard's Bible!
1971 Austin (Healey) Sprite - running turbocharged since 1993
5th Nov, 2011 at 09:54:45am
Welcome, there's a few Midgets lurking around here and an A35 but I think you're the first Sprite. Isambard Kingdom Brunel said:
5th Nov, 2011 at 10:21:30am
Cheers Rob. Been scooting through Steve1275's stuff - and noting one or two others to check up on. I ran my car at Santa Pod a long time ago - and despite clutch slip I got a 15.1s run. I have also sprinted it and had a go at production car trials too! Like steve1275, I ran a side pipe for a few years - 2" bore and exiting at a more oblique angle. My exhaust system now comes straight off the back of the turbo and down through the tunnel next to the gearbox - so no tight S-bend to get through the gap in the chassis rail. It then goes to the back of the car through a cherry bomb. 1971 Austin (Healey) Sprite - running turbocharged since 1993
5th Nov, 2011 at 11:20:32am
welcome to TM |
5th Nov, 2011 at 11:36:55am
Hello and welcome. I have started posting on Instagram also my name on there is turbomk1golf
5th Nov, 2011 at 01:55:41pm
Just posted couple of photos in 'Show us Yours' 1971 Austin (Healey) Sprite - running turbocharged since 1993
5th Nov, 2011 at 02:33:55pm
Hello and welcome On 11th Feb, 2015 robert said:
5th Nov, 2011 at 05:02:05pm
sounds very impressive, a warm welcome!
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
5th Nov, 2011 at 08:38:00pm
welcome,there are a few heretical right wheel drive guys here. 'Where does the engine go?' |
