Home > Beginners Tech > Drop gear question.
danb41
Member #: 9285
Oxfordshire
Could anyone tell me what the difference between a 24 tooth primary and input combination and 23. I know they both equal to 1:1 ratio but wondered why there are two ways of getting it.
Thanks
Dan.
wez
Member #: 9271
Stoke on Trent
Maybe something to do with the strength of the tooth, if the outside dia of the 2 types is the same then the 23 tooth type would have a slightly larger tooth.
Edited by wez on 8th Dec, 2011.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Its called a gear correction factor. I had a look at both of them together the other day, the the gears with more teeth are significantly thinner, to the point where I would never run a 25 tooth gear!
The gears are near enough identical sizes but the profiles are significantly different. Im guessing one would also be alot louder than the other.
If youre looking at the Minispares ones they are all interchangeable to make higher or lower ratios by either having a 24 primary and 23 input or a 23 primary and 24 input, but the 23 tooth 1:1 was known as the Turbo Challenge set being stronger through having bigger teeth
If your going for a 1:1 ratio, as Paul says the 23 tooth gears will be alot stronger.
danb41
Member #: 9285
Oxfordshire
It is the MiniSpares ones I'm looking at and would the 23 arrangement be louder? Also probably a noob question but could anyone explain the advantages of going for a ratio other than 1:1?
I'm using a 23 tooth primary and 24 tooth input on the next 998 turbo, simply because with a 3.105:1 diff it gives me a better FD ratio for my needs, 3.24:1.
and to add 23 tooth gear is ear splitting
so if you go for that expect to pay for a decent hearing aid sooner! ....lol
