Page: |
Home > Show Us Yours! > My '79 turbo project - Update 16/08/14 | |||||||
47 Posts Member #: 5199 Member Darlington/Devon |
7th Dec, 2012 at 09:42:57pm
Thanks for replying Dan, i like alot of the stuff on that site but never seen the pedal! may have to buy one of these! |
562 Posts Member #: 9285 Post Whore Oxfordshire |
7th Dec, 2012 at 10:25:45pm
No problem, i've got a few bits from them and it really is good stuff! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
3rd Mar, 2013 at 02:39:57pm
So a few of you may have seen i had some issues getting the thing started a few weeks a ago. It turned out to be the trigger wheel was put on 90 degs wrong. So some nights after work soon sorted this out and it runs! :)
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
3rd Mar, 2013 at 02:43:58pm
Looking good.
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
3rd Mar, 2013 at 03:31:51pm
Cheers Andy! Can't wait for some good weather and track time.
283 Posts Member #: 8215 Senior Member Rayleigh |
3rd Mar, 2013 at 08:04:33pm
Awsome work mate, first drives always exciting!! Dave the Cake |
6729 Posts Member #: 618 Post Whore Glasgow |
3rd Mar, 2013 at 10:06:46pm
Looking fine! |
3rd Mar, 2013 at 10:09:45pm
Cheers chaps! Will have to get some better videos when it's tuned. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
24th May, 2013 at 11:03:06am
So it's been a while since i updated this thread, and a lot has happened. The car has been set up for 9psi and its hilarious! Great fun and god knows what it will be like when the boost is turned up.
Edited by danb41 on 24th May, 2013. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
9311 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
24th May, 2013 at 12:51:28pm
CRUMBS!!
24th May, 2013 at 01:05:51pm
Cheers Nic, just need the bonnet painting and a few other bits and i will be happier. Suspension need setting up too. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
7262 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
24th May, 2013 at 01:25:06pm
Looks great!
In the 13's at last!.. Just |
361 Posts Member #: 114 Senior Member Porto/Portugal |
24th May, 2013 at 01:33:34pm
WOW, lovely... i like the bonnet in white Pedro Silva
10th Jul, 2013 at 04:18:38pm
Right so a bit of a downer update, I had problems with the clutch not disengaging properly which was causing some crunching into gears. An MED clutch arm / new clevis pins / system bleed and welding/ re-drilling the clutch pedal. The clutch felt as it should and all gears were great apart from 2nd!
Edited by danb41 on 30th Jul, 2013. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
10th Jul, 2013 at 06:22:56pm
That's exactly what mine did, mine was worse so I ended up rebushing it. You may get away with it by just taking off the high spots in the bush. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
10th Jul, 2013 at 06:26:32pm
That's bad luck mate. I have started posting on Instagram also my name on there is turbomk1golf
10th Jul, 2013 at 07:42:57pm
Yeah it's a pain in the arse, but i'm glad i've caught it at this stage! I have had the gearset apart tonight and 1 of the baulk rings sits right up against all of the gear cones I try. So this explains the crunching in 2nd. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
104 Posts Member #: 10210 Advanced Member Durban, South Africa |
11th Jul, 2013 at 02:49:02pm
Bit of bad luck on the gears but on the bright side you've got a bloody great looking car there. Life is always a matter of opinion and quite frankly, no ones opinion really matters. |
11th Jul, 2013 at 02:49:29pm
. Edited by Miniac on 11th Jul, 2013. Life is always a matter of opinion and quite frankly, no ones opinion really matters. |
12th Jul, 2013 at 06:44:03am
On 11th Jul, 2013 Miniac said:
Bit of bad luck on the gears but on the bright side you've got a bloody great looking car there. Cheers mate. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
30th Jul, 2013 at 02:12:53pm
So after some long days and evenings, the car is nearly back together! I've rebuilt the gearbox with some rather expensive "Genuine' baulk rings, and got a refund from Minispares for the baulk rings that pooped them selves.
644 Posts Member #: 9371 Post Whore East Yorkshire |
30th Jul, 2013 at 02:35:07pm
looking good
BHP sells engines, but Torque wins races! |
30th Jul, 2013 at 03:29:05pm
glad to hear your back on the right track. roll on MITP! |
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
30th Jul, 2013 at 03:58:31pm
looking spot on! Did this to drive through wokingham at all? |
5th Aug, 2013 at 02:32:31pm
So it's back together and the gearbox is working well! Just in time for MITP, and it's also booked in on a RR Thursday. Hoping for a nice bit of power and more rpm to use for the strip.
Page: |
