| Home > Help Needed / General Tech Chat > Transfer gear case bearings?? | |||||||
![]() 168 Posts Member #: 9709 Advanced Member Cirencester, glos |
22nd Dec, 2011 at 05:36:14pm
looking on the mini sites and there is so many bearings to choose from, which one do i need for the bearing on the end of the 1st motion shaft that goes into the gear casing and also for the idler gear??
![]() 207 Posts Member #: 9045 Senior Member Wolverhampton, West Midlands |
22nd Dec, 2011 at 05:55:58pm
Nose bearing (replace the outer race in the transfer case aswell, try not to mix and match):
Edited by Pauly on 22nd Dec, 2011. |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
22nd Dec, 2011 at 06:03:17pm
theres 3 different bearings, two of them are the same
Edited by Craigie-B on 22nd Dec, 2011. On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
22nd Dec, 2011 at 06:25:57pm
On 22nd Dec, 2011 Craigie-B said:
theres 3 different bearings, two of them are the same the two bearings that fit into the bell housing are the same and then you need two different ones. I bought the following: 1x http://www.minisport.com/mini-spare-parts/info_ADU7619.html 1x http://www.minisport.com/mini-spare-parts/info_AAU8424.html 2x http://www.minisport.com/mini-spare-parts/..._TUK100320.html Thats what I bougth to replace ALL of the bearings related to the drop gears (both the idler and 1st motion shaft gears, as well as the bellhousing casing bearings) EDIT: Mines A+ If yours isnt you just get the smaller idler gear bearing iirc All the bearings I got from Minisport were non genuine chinese crap. Now you might say "so What!" but if you take the time to measure the length of the rollers, you will find that they are shorter. Shorter means less load carrying, and an already highly stressed bearing, that is not such a good thing! There are two types of genuine A+ idler bearings, and the better one is the latest one by Torrington. There are also two different first motion shaft support bearings, depending on the trasnfer housing. There is the standard A or A+ and then there is the Turbo. There are not many Turbo housings knocking about and the chances are it will be the standard A or A+ On 26th Oct, 2004 TurboDave16v said:
22nd Dec, 2011 at 06:47:38pm
Mine is the A+, thank you guys for clearing that up. i think ill wait untill minispares have all the bearings in stock before i order. thanks again |
22nd Dec, 2011 at 07:03:04pm
Oh dear =[ well I'll see how well they fit into my engine and if they arn't perfect will send them back
22nd Dec, 2011 at 07:09:23pm
Oh dear =[ well I'll see how well they fit into my engine and if they arn't perfect will send them back Not sure what you mean, because they will deffo fit. On 26th Oct, 2004 TurboDave16v said:
22nd Dec, 2011 at 08:14:59pm
Just destroyed the brand new un opened idler bearing I put to one side from Minisport. Not only does the packaging have the part number for the Torrington bearing, but the outer race running surface has noticable etching in it, meaning it is trash before it's even been anywhere near a gearbox! This is something you would NEVER be able to see before you installed it, without having to destroy the cage.
7th Jan, 2012 at 11:41:26am
Hello all I had my bearings turn up during the week and the first motion bearing that goes into the transfer casing is too small. I think I have a genuine turbo transfer casing and the bearing are no longer available right?
7th Jan, 2012 at 02:24:11pm
Genuine turbo ones are still available. Edited by minimole23 on 7th Jan, 2012. On 7th Oct, 2010 5haneJ said:
