Home > Help Needed / General Tech Chat > Mega jolt and trigger wheel set up guide ?
Beno174k
Member #: 9548
Manchester
My main question is how do u position the trigger wheel and the sensor sorry if this has been covered I did search also is there a fitting guide start to finish ?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578
This will get you started
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=135459
and then..
http://www.turbominis.co.uk/forums/index.php?p=search
Edited by madmk1 on 24th Dec, 2011.
dig-mini
Member #: 9269
Rotherham
Get the engine to top dead centre then where ever the trigger wheel is at the sensor should point at the 9th tooth before the missing tooth. And you should be using 36/1 trigger wheel
Good luck
Craig
Beno174k
Member #: 9548
Manchester
Thx guys much man love
