Home > Help Needed / General Tech Chat > Deseaming ?? how
Dangerous
Member #: 417
I know you do a bit at a time to stop the panels distorting,but do you weld an @ 1" wide strip on the inside too.
What about the below boot bit where 3 layers join.
*oh well*
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
no idea, i bought my shell ready deseamed, lucky me! ... just hope the guy did a good job welding *indifferent*
nutter driver
Member #: 47
Not very sunny swanage
ask jimster..... he's done the bit below the boot iirc.....
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
http://www.afracing.com/projects/mini7.htm
AlexF
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The rear lip is easy... just grind back the lip, which is three layers of metal (valance, boot floor and hinge pannel) then seam weld.
The body I did from the inside where possible as its easier to get a strong weld. I also reinforced the rear seams with a few extra strips.
Distortion was minimal but weld a max of 2" and then letting the pannel cool. You can get away with doing top then bottom. I also used the trick of weld 2" miss 2".
You HAVE to be good at welding thou, or the whole car is going to fall apart on you!!
Alex
AlexF
Dangerous
Member #: 417
Great idea welding from inside,I had practise on my spare half a shell from the outside with not much joy as the wire kept going through the gap,prob remove the inners behind rear window too
Not bovvering with the roof,and the front is only windscreen length as getting flipfront with a panels attached
Edited by Dangerous on 24th Apr, 2005.
Powelly2008
Member #: 5042
Would welding a 1" strip on the inside of the grinded seam then mig welding the outside to finish off the weld then grinding it down work or would it not be strong enough. I would be doing this at a length at a time to make sure there is no distortion within the shell.
as alex, i welded from the inside where possible before i even started to grind away the seams. then where you cant get to you just grind away a bit of the seam, weld. leave it, then do more.
i am abit unhappy with a few parts where they were done from the outside and then ground back and now that i have access to all of the seam i will be putting some light plating in for that extra bit of peace of mind.
Powelly2008
Member #: 5042
Ah yes i see what you mean now instead of faffing about with a strip of unsupported metal it is already joined together from the inside,
Thankyou very much.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
I ground off a few 2 inch sections along the boot seam, then welded those, ground off the rest, then welded it all.
So it was never a loose panel like you say.
Not sure about the rest of the car. I know when its done you use a chisel or something to knock the two meeting panels in abit as fill the 'dent' with weld, otherwise you have your welds sticking out shit loads.
Build Thread Click Here
Powelly2008
Member #: 5042
Yes i am thinking of doing the same
Thankyou for the advice
AllanMcD
Member #: 414
Dalbeattie Scotland
I did one near 30 yeras ago when I was 17 with oxy accetlene I welded about 1/2 an inch and cooled it with a wet rag it worked ok but was a hell of a job.
Allan
ps I choped the roof at the same time
http://www.rabdunn.co.uk/
Powelly2008
Member #: 5042
I believe it is going to be a nightmare im not looking to chop the roof thats abit too far for me!
Jac
i was looking at mine the other day and seriously thinking of roof chopping...then i thought i cant be assed with all that extra hassle, and it would look abit out of proportion with a large clubby front on it.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
I quite like it on some minis, gives it that sort of hot rod look I think.
Depends what the rest of the cars like though as to whether it looks good im my opinioinoion.
i havent really seen it done on a clubby, and picturing it in my head it looked all abit too long. you would have to go quite wide for it to start to make sense and look really nice. IMO but hey, that was all just from a picture in my head! alcohol has already damaged that!!!
