Home > Help Needed / General Tech Chat > Standard pistons ok?
benspickup
Member #: 9608
Lincolnshire
I am aiming to turbo my pick up. I want to use the mirage manifolds with either a t2 or gt17' can I use the standard pistons in my a+ engine and just increase the combustion chamber size to lower the cr. I wil be using a carb and dizzy of a metro turbo, inter cooled and aim for 10-15 psi. Thanks
benspickup
Member #: 9608
Lincolnshire
Also will standard size feed and return fuel pipe be ok? I intend to use a t piece back into the line from the tank between it and the pump. Only because the pick up uses a screw in olive into the sender for the pick up pipe.
std A+ pistons arnt really up to much, a std set of metro turbo pistons would be fine though.
for the feed and return I'd say go up in size, alt least for the return. also search on here for "T peice trick"
danb41
Member #: 9285
Oxfordshire
Joe C, just had a butchers for the ''t piece trick'' and didn't have any luck. Got a link?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
danb41
Member #: 9285
Oxfordshire
Ah Tee. Cheers!
