Home > Help Needed / General Tech Chat > can you turn a n/a hif44 carb into a turbo carb ?
oliver122
Member #: 9625
pretty much as the name says really , was just a thought i had last night while clearing all the snow off the drive lol
wez
Member #: 9271
Stoke on Trent
have a search......
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
liam mini 35
Member #: 9125
Sheffield, South Yorkshire
yes you can. i found it on the search function have a look. think it may even be in the FAQ section
The turbo build has finally started
oliver122
Member #: 9625
thats brilliant if i defently can , ive been searching for a metro carb with no luck , and i can get my hands on a cheap hif44 xD
Billus89
Member #: 8931
Try this link. Somewhere down it there is a rough guide of replacement parts needed to convert to forced induction applications
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1153
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=241013
oliver122
Member #: 9625
so as i understand , all you need to do is buy a turbo carb rebuild kit and then rebuild an N/A carb with that kit and there you have a carb capable of running boost through it ?
you need to run the t peice mod on the float bowl ( search again covered many times)
or you can actually drill the air ways into the na carb body like i did, they are already part drilled you just need to go the extra 5mm or so
if your going to use the metro turbo inlet manifold you will have to redesign the throttle cable and choke cable arrangement because of clearance issues
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Johnny
Member #: 6926
Accrington
i have a turbo carb if you need one
Pm me if interested
