Home > Beginners Tech > Metro Turbo Engine Myths
TurboDave16V
Yes - you can see it has a really thick land between the crown and top ring. A very well designed 'turbo' piston.
gutted
Member #: 645
Derby
Maybe not true with all turbo heads, but I've been told that there is a capital 'T' stamped into the head next to where the edge of the rocker cover sits, at the thermostat end.
Whether true or not for all turbo heads, it certainly is the case for both Metro Turbo heads I've got at home.
Metro turbo owner
Nope, that is tosh I am afraid.
gutted
Member #: 645
Derby
I can provide you with a picture, if you like. I've recently rebuilt my engine, and have installed a new 'head - I can 100% confirm that's the case for the old head I removed and the recon head I've installed and recently painted. The original head has been on the engine since new, and the recon head is one I picked up from some guy in West Midlands - I had never noticed it before, but the engine builder who reconditioned the head (Peter Burgess) pointed it out to me when I picked it up after he'd finished with it. He compared it to a standard 1275 head, and went as far as to say "you can tell your one is genuine because of this mark"
EDIT: can only confirm it for my own engine, though. As I said in my original post - maybe it's not the same for all engines. Mine's an '89. I don't have the engine number to hand, but will post it (along with a pic) when I get back home if it helps any.
Edited by gutted on 7th Feb, 2007.
Metro turbo owner
Turbo Shed
Member #: 30
Epsom, Surrey
i think most, if not all had the "T" stamped in them
gutted
Member #: 645
Derby
Ah - that would explain why I'm wrong then! :) Apologies for any confusion, in that case.
Metro turbo owner
metroturbo
Member #: 989
North Yorkshire
My old cylinder head has a T stamped into the head at the end where the mini heater take off is, as does the replacement I got from a Turbo engine. By all, do you mean all A series engines?
Edited by metroturbo on 7th Feb, 2007.
Turbo Shed
Member #: 30
Epsom, Surrey
i think the "T" stands for "Turbo"
T stands for turbo but not all of them had it by a long way.
So if it does have it, you can pretty much say its a turbo head, if it doesnt have it then it can still be a turbo.
Therefore, it is a myth that all turbo heads have a T stamped in them.
Personally I have seen 3 or 4 turbo heads (with the large stem exhaust valves) without a T stamped on them, and also 1 or 2 with the T.
This is not meant as a general discussion thread, it is meant as a reference thread, so I'll tidy these posts up in a day or two.
racing_is_life
Member #: 1426
Birstall, Yorkshire
Is there any difference in the con rods in the turbo motors vs the n/a motors? I've heard different people say different things.
No difference at all, turbo engines just have 1275 A+ rods no different to any others.
Olish
Member #: 1650
New Caledonia
Can I ask you if there is any diference with the flywheel and clutch??? in the turbo motor vs the n/a motor ???
"Good judgment usually comes from experience; and experience usually comes from bad judgement"
Olish
Member #: 1650
New Caledonia
...and what about the gear box ??? stronger or another myth...
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Back in the early nineties, seem to remember an article in Car & Car Conversions that Metro Turbos up to 1985-86 had hardened cranks....can't remembers the exact year
One of those silly little details one remembers *wink*
On 10th of May, 2005 at 02:58pm Tom Fenton said:
Hmm thats interesting I thought the early ones were the better ones! Oh well you live and learn.
I don't claim to know everything there is to know about Metro engines, the plan was to have a bash at the write up above, wait a week or so for comments from you lot and then re-write and edit as required.
Keep the comments coming, cheers!
On 19th Jan, 2010 wil_h said:
If the cranks is marked CAM 6581 then it's the "hardened Turbo crank". These only seem to appear in a few engines but do seem very hard wearing, otherwise it's "stock" A+ crank 6232.
Somebody was going to do a harness test on the two to see the difference, don't know if it ever happened ?
Turbo clutch ios an uprated version compared to the N/A version.
The nose bearing on the turbo gear box is also larger than the N/A version. I believe this helps prevent input gear damage.
TurboDave16V
On 9th of May, 2005 at 06:23pm Tom Fenton said:
For comment please all
6) The nose support bearing on the end of the first motion shaft is different (larger) on the Turbo engines. The reason this was done is not clear. The bearing in the larger Turbo size is still available.
We got that one down - but good shout on the clutch. :)
Olish
Member #: 1650
New Caledonia
...sorry for the stupid question... *frown*
TurboDave16V
Hey grumpy...
*tongue*
The transmission is completely standard aside from the FD and the input bearing (as mentioned). It isn't 'toughened' in any way. *smiley*
chinlesswonder
Member #: 1192
In the garage......again!!
As i recall, the MG Metro cam was specifically designed for the metro turbo, but produced too much bhp so was swapped for standard and stuck in the 1275 MG. BL not wanting warranty issues.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
TurboDave16V
Well, I've never heard that before; and I don't actually believe it TBH as the MG nat-asp came out before the turbo...
Lone Wolf
Member #: 1092
Yours from the Funny Farm
what about the diff?
i seem to remember reading somewhere that metro turbos suffered broken diff pins because BL removed something from the pin, a special coating was it?
probably just a loada bollocks but i thought id mention it
Warning:Stig in Training
The Turbocharger:God's Finest Minute
I've never heard that before, sounds like horse shit to me I'm sorry to say.
Carl S
Member #: 1761
Stalker
Whoa, that's a fantastic collection of information there Tom! It's certainly answered a lot of the questions I had, and wanted to ask about the A series engine.
Edited by Carl S on 12th Jun, 2007.
