| Home > Help Needed / General Tech Chat > Megajolt Connection | |||||||
26 Posts Member #: 9124 Member |
9th Apr, 2012 at 02:47:39pm
I might regret this post, but oh well!:$
9th Apr, 2012 at 03:43:37pm
You can 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Apr, 2012 at 08:22:01pm
So you can use the original point on the carb then?
9th Apr, 2012 at 08:26:03pm
Yes I'm using the nipple for the dizzy Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
9th Apr, 2012 at 08:41:44pm
the thing is the throttle interferes with that port, if you look at the way the carb controls the vacuum just off idle and at part throttle you will understand what i mean, it does not give correct 'read-out' of the manifold pressure it is used to control the vacuum advance on a mechanical dizzy
Edited by Brett on 9th Apr, 2012. Yes i moved to the darkside |
9th Apr, 2012 at 08:48:52pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=336413 Yes i moved to the darkside |
10th Apr, 2012 at 08:19:02am
Cheers for the replies and various links, makes sence now!
