| Home > Help Needed / General Tech Chat > K head conversion, timing cover and jackshaft thrust plate questions | |||||||
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
5th May, 2012 at 12:00:36pm
Searched. Looked at all the K head conversion pics and explanations I could find. Now I am cutting my plastic mockup pieces before cutting metal. But I am not happy with the block front (timing) cover designs I have seen. Most of the timing covers I have seen use a cam/jackshaft pulley similar to those old belt-drive conversions, the ones for replacing the stock timing chain with a belt. Those pulleys have a large diameter spindle with a big machined recess, big enough to allow a socket in there to tighten the Mini cam/jackshaft nut. Then the big spindle needs a big oil seal, and the seal needs the cover to have a big hole, and so on. I have one of those on an engine over in the corner, I will take a pic and post it here later (camera needs charging).
Edited by scooperman on 5th May, 2012. |
5th May, 2012 at 12:09:24pm
There's lots of pics on my build thread of how I did mine.
5th May, 2012 at 07:29:02pm
I never understood wht the cam thrust plate only has one babbit face when both sides bear thrust loads. This is one reason I decided that a thrust of aluminium woul work just fine. The cam no longer bears any real load anymore other than the oil pump. On 26th Oct, 2004 TurboDave16v said:
5th May, 2012 at 10:21:48pm
A flat tappet cam shouldn't walk a lot. However, that clockwork distributor gear put some wobbles into the cam every time a valve spring accelerated/decelerated the cam within the chain slack. My impression was that the oil pump took any inward load, and the thrust plate took the outward load. I have looked at many old thrust plates and didn't see much wear on the gear side, only the cam side. Anyway, one more reason to get rid of the distributor. |
6th May, 2012 at 02:47:10pm
Oil pump takes no thrust load. The thrust plate takes it all in both directions On 26th Oct, 2004 TurboDave16v said:
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
7th May, 2012 at 08:36:30am
You can have a look at my build thread aswell, it its similar to matty's.
7th May, 2012 at 10:59:56am
thank you Matty, Sprocket, Pinky. I went back and read them all again, mucho good stuff. I also found a Sprocket build thread on the Efiminis forum, but the pictures are all gone, just text now.
Edited by scooperman on 7th May, 2012. |
7th May, 2012 at 08:14:31pm
The thrust plate prevents thrust movement in both direction within the specified tollerance. If the cam is touching the oil pump housing, which it can, you need to use a thicker front plate gasket, which is why good quality gasket sets supply either one thick gasket, or two different thickness gaskets for the same application.
8th May, 2012 at 12:44:14am
well dog bite my cats, Sprocket is correct. I found old thrust plates and there are witness marks on the steel side. How do I come up with tolerances/numbers to design a new timing cover, should I try to copy the measured amounts from an old engine, or is there some spec? |
