| Home > Help Needed / General Tech Chat > Brake bias help | |||||||
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
5th Jun, 2012 at 08:47:53am
I'm getting rid of the servo and replacing it with the single system type master cylinder. My question is can you use the cast brake compensator bit that bolts on the bulkhead? As it has four inlet/outlets and with the single master cylinder i would only need two.
5th Jun, 2012 at 08:52:33am
No, dump that too. You need the compensator valve that was fitted to mk1,2&3 but theyre getting hard to source now I seriously doubt it! |
5th Jun, 2012 at 10:01:22am
Is it very important to use a compensator valve? Do people run without them.
5th Jun, 2012 at 10:31:32am
I have a compensator valve :) but I shall be using it as running Remote servo aswell, but newones are a bit pricey |
5th Jun, 2012 at 03:30:18pm
You dont need a compensator if using adjustable bias.
7th Jun, 2012 at 05:38:47pm
Cheers fella's. So if i get hold of a adjustable bias valve, all i'm going to need is a four way union to link it all together? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
9th Jun, 2012 at 08:35:49am
?? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
9th Jun, 2012 at 03:56:51pm
Im using a 3 way union on the bulkhead like the mk1's use and a single line to the rear with a bias valve plumbed inline. Edited by matty on 9th Jun, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jun, 2012 at 03:59:38pm
Excellent, cheers matty. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
