Home > Help Needed / General Tech Chat > Anyone had experience with one of these?
danb41
Member #: 9285
Oxfordshire
Just searching for a manual boost controller. And after reading bad things about the cheepo ones causing boost spikes/creep, i'm after a decent one!
I've read good things about these.
http://www.boostcontroller.com/index.php?i...%26category%3D5
Anyone recommend any others or is an electronic boost controller the only option for consistency?
Dan.
bennyy
Member #: 9037
Doncaster, yorkshire
Just get a bleed valve, much cheaper, mine was about £10-15 from turbo Phil, holds boost perfectly
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
evolotion
Member #: 83
Glasgow, Scotland
yip just get a bleed valve. Ball and spring style Manual boost controllers are great when they work well (and most do, reliably) but occasionally they mess up, you cant really go wrong with a bleed valve.
Denis O'Brien.
danb41
Member #: 9285
Oxfordshire
Cheers, a bit over priced then really.
Benny: just the brass type you use then.
Im using an electronic boost solenoid from a saab and a bleed valve. The bleed valve to set max boost (at 2nd stage) and the solenoid to switch it to higher boost. If you're running MJ im sure you can use an output to trigger at set rpm/boost?
danb41
Member #: 9285
Oxfordshire
Im afraid i havent had any experience with MJ yet matty.
