Home > Help Needed / General Tech Chat > urgent help, pot stuck on diff
eden7842
Member #: 8852
leicestershire
Hi
Got my mates gearbox and we carnt get the pot off the diff.
I assume the clip has broken? How do I go about removing it?
before I use my bl service tool
Chalkie
Member #: 9764
Northamptonshire.
I normally clamp the box to the floor and use a crow bar -_- try slide it off that way
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=346471
mercenary62
Member #: 9937
yep large crowbar about 4ft long is how i deal with stuck pots
give em hell
Alex
Member #: 1851
Woolavington, Zummerzet
I've got the proper Churchill tool for removing pot joints (though a sensibly placed crowbar does just as well) and every so often I get one that just won't come off.
Turn the joint 180° and try again - if it's lined up wrong the circlip can fall down deeper intot he groove and noting will get it to shift.
blunt chisel and hammer straight in between the side case and back of pot joint.
You arent trying to hammer the joint off, just use the taper of the chisel to price the two apart.
