Home > Help Needed / General Tech Chat > Differential roller bearings
danb41
Member #: 9285
Oxfordshire
Do you have to shim any preload with the Minispares roller type diff bearings? And if so how much do they need?
These are the ones i'm on about. http://www.minispares.com/product/Classic/...k%20to%20search
Dan.
Chalkie
Member #: 9764
Northamptonshire.
Two of these main diff carrying bearings are required in the gearbox and this new steel caged type fits either way round--The 3/4" width outer track type had a side marked "thrust side" which must face away from the gearbox. These usually shim up at 4 thou pre load as opposed to the very early non thrust type bearings which were 1-2 thou.
says in desc
Edited by Chalkie on 1st Jul, 2012.
danb41
Member #: 9285
Oxfordshire
It's written rather badly. So i asked to make sure.
So 4 thou for these then?
Chalkie
Member #: 9764
Northamptonshire.
I know its badly written try 4 thou and see what its like :) i'm not 100% sure though
I won't take that at face value, fit them and measure as it says in the haines book of lies.
danb41
Member #: 9285
Oxfordshire
Cheers! I will do.
