| Home > Help Needed / General Tech Chat > Inertia switch wiring | |||||||
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
19th Jul, 2012 at 08:00:45pm
I've got hold of an inertia switch from a rover, which i want to use to cut the fuel pump out incase of an accident. Can anyone tell me how i go about wiring it in? Is it a case of putting it inline to the fuel pump, or something more??
19th Jul, 2012 at 08:24:52pm
It wires directly inline with the fuel pump power supply (with the switch in it's 'set' position). Pin 1 (common) and 3 (normally closed). You can use the normally open contact, pin 2 to supply 12v to a warning light on the dash making it plain to see that the switch has tripped and the fuel pump is not running, instead of getting confused as to why the engine stalled and then won't start again lol
19th Jul, 2012 at 08:27:00pm
does that happen then LOL
On 19th Jul, 2012 Sprocket said:
the switch has tripped and the fuel pump is not running, instead of getting confused as to why the engine stalled and then won't start again lol On 28th Aug, 2011 Kean said:
19th Jul, 2012 at 08:32:34pm
Just what i was looking for Sprocket! Is there any particular place that's best to mount it? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
19th Jul, 2012 at 09:16:45pm
Somewhere you can get to it easily lol. Obviously upright On 26th Oct, 2004 TurboDave16v said:
19th Jul, 2012 at 09:32:01pm
Cheers, i remember watching that vid a while back haha My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
