| Home > General Chat > battery cable channel holder type thingmybob and petrol and brake line brackets | |||||||
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
15th Aug, 2012 at 06:21:21pm
hi all been busy scraping all the cack and old underseal of the bottom of my mini , all was fine until i started poking at the battery cable holder channel ,it was rotten through in two places so i just ground it off ,also fuel line and brake pipe brackets are a bit rusty ,managed to clean these up with the grinder ,but underneath them look a bit corroded ,thing is now ive come this far cleaning the underside back to fresh metal can i just cut these brackets off and use something else ,any ideas would be appreciated give em hell |
![]() 1014 Posts Member #: 238 Post Whore essex |
15th Aug, 2012 at 06:54:47pm
I've used rubber lined p clips. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
15th Aug, 2012 at 07:11:30pm
did you use them on brake pipes,fuel lines and battery cable mate? give em hell |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
15th Aug, 2012 at 07:18:39pm
that Johnbetts chap is selling some hose clip things. should find him in the traders section |
15th Aug, 2012 at 07:21:48pm
Ive only used them on the fuel lines so far, but I will eventually use them on the brake lines and battery cable. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
15th Aug, 2012 at 07:29:41pm
ok to use for mot purposes then ?take it they just poprivet in place give em hell |
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
15th Aug, 2012 at 07:31:22pm
Apbellamys used some nice clips for his fuel lines in his build thread, look really tidy
Avon 2010 class c 3rd
15th Aug, 2012 at 07:33:49pm
Fine for mot use, and yes I fixed them with rivets. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
15th Aug, 2012 at 07:35:55pm
ok thanks guys il be using stainless steel p clips with rubber inserts,and stainless steel rivets give em hell |
15th Aug, 2012 at 07:44:01pm
This what I've done:
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
15th Aug, 2012 at 07:49:40pm
As above stainless rubber lined p clips. I've used them for fuel lines and battery cable. I think they look tidy! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
15th Aug, 2012 at 08:47:47pm
thanks andy appreciated guys give em hell |
15th Aug, 2012 at 10:48:02pm
Id run the battery cable inside :) its protected by the channel so it dosen;t get cut or broken (so ive been told) so run it inside under the carpit it be fine :) |
