Home > Help Needed / General Tech Chat > Ford Motorcraft coil packs.
danb41
Member #: 9285
Oxfordshire
Is there any differences, apart from size and the different HT lead types needed with the two types of coil pack found on various fords. I have one of each, and wondered if i would benefit from using one over the other.
Dan.
jamie@thefatgarage
Member #: 9345
Sheffield
I've used both, not noticed any difference apart from the HT leads on one type need a hammer or someone who tears phone books to fit them.
The cossie boys seem to like the older bigger coil type.
danb41
Member #: 9285
Oxfordshire
Hmm i wonder why they prefer the bigger type? Its the bigger type that you need a grip like a gorilla to get the leads off! *laughing*
Speaking to my rolling road operator, there is a perception the spark is stronger, So they use them when the boost is high.
I never saw a difference as I tried both but I only run 12 psi, I stuck with the older larger type.
