| Home > Help Needed / General Tech Chat > Oil pressure/oil feed fitting help! | |||||||
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
26th Aug, 2012 at 06:27:43pm
I'm in need of an oil fitting. It needs to be a 4 way or the shape of a + sign. As i have the oil feed to go in it, the oil pressure gauge and oil light to attach to it.
389 Posts Member #: 9751 Senior Member Derbyshire |
26th Aug, 2012 at 07:27:31pm
This sort of thing??
26th Aug, 2012 at 07:32:02pm
Yeah thats the one, just need to check the thread sizes are correct. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
26th Aug, 2012 at 08:25:06pm
I got mine of ebay was only a couple quid Yes i moved to the darkside |
26th Aug, 2012 at 08:27:41pm
Same as the link above Brett? Or do you have another link? I think i saw a nice one in Simons mk1 thread? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
26th Aug, 2012 at 08:32:11pm
I cant see a link i will go look on flea bay Yes i moved to the darkside |
26th Aug, 2012 at 08:40:16pm
I cant find the actual one, ebay mobile isnt great for searching but mine is same as this with 2 holes on the side.and one on top
Edited by Brett on 26th Aug, 2012. Yes i moved to the darkside |
26th Aug, 2012 at 08:45:20pm
Got the link working, but it seems that style only has two outlets? Is that what you use Brett? I'm after a reasonably small fitting with 3 outlets. 1. oil pressure gauge 2.oil pressure light switch 3. oil feed fo turbo.
Edited by danb41 on 26th Aug, 2012. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
26th Aug, 2012 at 08:53:38pm
Here is Brett's link
Edited by mossy2a on 26th Aug, 2012. |
26th Aug, 2012 at 09:55:17pm
http://www.ebay.co.uk/itm/Radial-T-Piece-O...=item3f17de7eff
26th Aug, 2012 at 10:14:02pm
Cheers guys, that will do nicely! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
