Home > For Sale > Also selling up part 3
oli79
Member #: 8480
Turbo kit all 5000 miles use, mirage manifold altered to take a gt17-3 threaded holes drilled out on turbo, 1 reverse studmto manifold with k nut on, includes air filter pipe shown, block adaptor and oil feed pipe, home made oil return, return flouro lined hose and clips, home made outlet elbow with lambda bung and mirage downpipe, mate to a 2" system, gt17 turbo was new genuine saab-Bargain £550 SOLD
Engine end/rad bracket assembly-£25 posted
Nice rocker cover set up, quite a few chips to paint, chrome cap, t bars ect-£30 posted
Plastic fan-£10 posted
1275 Pulley plus servicable belt-£10 posted
Ultralite flywheel pre verto, lightened backplate with 1mm off lugs, grey diaphram, used friction plate may need binning £170 posted the lot
Edited by oli79 on 30th Aug, 2012.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
danb41
Member #: 9285
Oxfordshire
PM'd
minidan
Member #: 7107
essex
ill take the dsn spacer pm me your pay pal
thanks dan
I'll have the dipstick.
Edit: or not as the case may be...
Edited by apbellamy on 27th Aug, 2012.
charlieb150
Member #: 9931
brighton
do you still have the rocker cover
kappa
Member #: 9854
Hounslow, Middlesex
sorry i may of read wrong, but is this the complete engine for sale with all the turbo gubbins?
