| Home > Help Needed / General Tech Chat > CoilPack Power Cable? 20a? | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
28th Aug, 2012 at 09:57:31pm
Hey guys, I was doing a search for fuse ratings and found this topic:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
28th Aug, 2012 at 10:09:00pm
The coilpack should have a seperate power supply/fuse. They can come off the same fuse on the fusebox (30A), but then have another inline fuse at 2A for the supply to the megajolt.
Edited by matty on 28th Aug, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th Aug, 2012 at 06:26:34am
Hello Matty,
29th Aug, 2012 at 06:32:15am
I would be very surprised if the coil pack took anywhere near 20A. The race car uses about 4A in total when running which is basically the MS, EDIS and coil pack. You will get away with 1mmsq, but 1.5mm might be better.
http://www.twin-turbo.co.uk
29th Aug, 2012 at 08:25:23am
so I should just put a 5a fuse in for the MJ so it includes enough for hte MJ and the coilpack? On 10th Mar, 2012 theoneeyedlizard said:
29th Aug, 2012 at 09:40:57am
yeah, the coil packs draw 7A peak, which probably less than an amp normally depending on rpm On 28th Aug, 2011 Kean said:
29th Aug, 2012 at 12:21:03pm
if it draws 7a peak then should I get a 10a fuse for the MJ? as, in theory, itll pop the fuse. If the MJ draws 3a and the coil draws 7a peak then as they aer both connected I should need a 10a fuse? On 10th Mar, 2012 theoneeyedlizard said:
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
29th Aug, 2012 at 04:47:11pm
Main Build
29th Aug, 2012 at 08:42:30pm
The MJ he has there is an older version than mine, The molex plug for mine above is above, said to put the power for the coil on the MJ so the hardcut limiter can cut the power when it needs to.
29th Aug, 2012 at 08:53:36pm
10A fuse is about right maybe 15A, its protection for the wiring if anything goes wrong rather thsn to protect the coil/ edis On 28th Aug, 2011 Kean said:
29th Aug, 2012 at 09:00:58pm
does it matter then that the wiring is tiny (like the original wiring on teh coil connector) ?? On 10th Mar, 2012 theoneeyedlizard said:
29th Aug, 2012 at 09:20:50pm
sort of not,
30th Aug, 2012 at 07:41:41am
