| Home > For Sale > Nippon Denso alternators 40A...and plugs | |||||||
16th Sep, 2012 at 07:32:42pm
My mate has finally decided to part with the final lot of ND alternators that he's been keeping for future projects, but no longer thinks he'll use them. I think he's got about 10 if anyone is interested. They are new and £70 free post to UK.
Edited by matty on 2nd Dec, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
16th Sep, 2012 at 09:08:48pm
I'd buy one but need over 40A and all the little Nippon Denso ones that keep coming up for sale are only 40, don't suppose he has any higher rated? www.topcatcustom.co.uk |
17th Sep, 2012 at 03:26:10am
If you search about i have posted an output graph for one of these 40A alts there 40A just off idle and around 60A at typical engine speeds i have no probs with a 40A on mine running all my gadgets/laptop/lights Yes i moved to the darkside |
17th Sep, 2012 at 07:03:20am
Some pics in relative. Size would sell these matty
17th Sep, 2012 at 10:43:39am
Thats promising, mine's being built for stage rallying, which means up to 6 main beams, wipers etc www.topcatcustom.co.uk |
17th Sep, 2012 at 10:56:45am
Here's a bit more info. The one pictured below is a 45A one but the 40A ones are almost the same apart from the charging lug comes out of the side, and the 2 pin plug is different. I'll be seeing my mate in the next few days, and I'll grab a pic of the 40A ones.
17th Sep, 2012 at 10:57:00am
On 17th Sep, 2012 topcat said:
Thats promising, mine's being built for stage rallying, which means up to 6 main beams, wipers etc 6mains will be getting on for 50A at least no? I would guess the 60A alts put out 80odd Amp above 4krpm would be bettersuited i think Yes i moved to the darkside |
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
17th Sep, 2012 at 11:58:59am
I've had one of these on for several years and been very pleased with it.Always manages to keep the batt.charged.Might be worth saying you need to do the all thread rod thing to support the lug on the water pump,otherwise it will break with one of these hung off it. 'Where does the engine go?' |
17th Sep, 2012 at 12:03:20pm
Jesus just seen on eGay you can get 130W bulbs!!! Would surely melt the lamps though, so will stick with 100W or below, so should just about be ok with one of these alternators...
17th Sep, 2012 at 12:19:21pm
The one pictured is the same as mine Yes i moved to the darkside |
17th Sep, 2012 at 01:19:09pm
Hi mate, Do they have a 3 pin plug if they do put me down for one.
17th Sep, 2012 at 02:59:05pm
Hi mate, I think they are the same as the ones before, I haven't seen them yet but they should be. I let you know when ive double checked. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th Sep, 2012 at 03:56:44pm
Cool if they do mate i will have one then. I have started posting on Instagram also my name on there is turbomk1golf
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
17th Sep, 2012 at 04:33:01pm
PM'd My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
19th Sep, 2012 at 06:20:53pm
Here's a pic, they are the same as the ones before. It may be possible to get hold of the plug to go with these too, to save to hassle of sourcing elswhere.
20th Sep, 2012 at 08:43:26am
Done i will have one mate. I have started posting on Instagram also my name on there is turbomk1golf
24th Sep, 2012 at 07:09:10pm
No problem Simon.
17th Oct, 2012 at 08:50:03pm
My mate has managed to source some plugs for these they are £13 posted or £10 with an alternator.
547 Posts Member #: 2928 Post Whore peterborough |
17th Oct, 2012 at 08:53:32pm
Are the plugs £10 if we got the alternator previously from you, or is that too cheeky? Jack Jones |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
17th Oct, 2012 at 11:36:51pm
i will take a plug mate, especily if the deal above is a goer...!?
19th Oct, 2012 at 08:40:54pm
I'll ask and see what he says. :) https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Oct, 2012 at 06:50:48pm
Ive asked but its only £10 for plugs bought with the alternator as they are expensive to buy in and he wouldn't make anything on them, what with postage, packaging etc.
869 Posts Member #: 2443 Post Whore Cheshire |
22nd Oct, 2012 at 12:09:29pm
Hi Matty,
22nd Oct, 2012 at 07:15:12pm
The main lug needs filing back to bring the pulleys inline and the adjustable bracket needs extending, and a shorter belt if you want to bring the alternator but that abouts it right close up to the block, but thats about it.
23rd Oct, 2012 at 03:55:05pm
Just received 2 today, well packaged and super fast delivery..... many thanks Matty and your friend.
