| Home > General Chat > can anyone make me an RTS clutch | |||||||
31 Posts Member #: 747 Member |
2nd Oct, 2012 at 04:59:32pm
Hi guys. I was wondering if there was anyone on TM that could make me an RTS clutch. Cheers, Adam
2nd Oct, 2012 at 05:05:25pm
Sprocket. On 11th Feb, 2015 robert said:
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
2nd Oct, 2012 at 05:43:14pm
is the RTS clutch really worth it though?
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
2nd Oct, 2012 at 05:46:04pm
Yes. It saves you using a pre-verto with a really heavy spring and risking ruining your thrusts. On 11th Feb, 2015 robert said:
2nd Oct, 2012 at 05:49:14pm
432 Posts Member #: 7856 Senior Member Essex |
2nd Oct, 2012 at 05:51:29pm
Have a search, the RTS only can be a verto! |
2nd Oct, 2012 at 05:51:42pm
do a search Craigie... On 11th Feb, 2015 robert said:
2nd Oct, 2012 at 05:51:51pm
yep, they are the tits IMO,
2nd Oct, 2012 at 05:57:29pm
sounds like i need to do this modification too! |
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
2nd Oct, 2012 at 06:00:10pm
This might be a silly question, but how do you identify verto springs? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
2nd Oct, 2012 at 06:04:29pm
thickness,
2nd Oct, 2012 at 06:08:08pm
It's the best clutch I've had.
In the 13's at last!.. Just |
2nd Oct, 2012 at 06:22:41pm
Cheers joe, is there anyway of confirming this? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
2nd Oct, 2012 at 06:25:48pm
Where did all of you that are running an RTS get one from? |
2nd Oct, 2012 at 06:33:04pm
Made em. If something is worth doing, it's worth doing half of. |
2nd Oct, 2012 at 06:48:31pm
Easy to do? I've looked through a few of the posts and got a bit blown away by the techy stuff. |
2nd Oct, 2012 at 07:03:55pm
i made em :)
Yes i moved to the darkside |
2nd Oct, 2012 at 07:12:46pm
I'll read it again and see if I can get my head around it. Would no doubt be easier with the bits and pieces at hand. I asked sproket, but don't think he makes them anymore. |
2nd Oct, 2012 at 07:16:54pm
does it have to be made from 2 brand new clutches? Or could I use my old turbo clutch, my new turbo clutch and a brand new turbo friction plate?
2nd Oct, 2012 at 07:18:05pm
its not that hard,
2nd Oct, 2012 at 07:19:46pm
On 2nd Oct, 2012 Joe C said:
apart from that, your just drilling the rivets out, tapping the holes they leave M8, and using m8x20 capheads to put it back together agian. On not as the case may be
Why over complicate things
2nd Oct, 2012 at 07:21:12pm
as long as the cluches are in ok condition 2nd hand ones are fine, just check the friction surface, crank taper hole, and the springy fingers for weare in the middle.
On 2nd Oct, 2012 Craigie-B said:
does it have to be made from 2 brand new clutches? Or could I use my old turbo clutch, my new turbo clutch and a brand new turbo friction plate? Furthermore, I take it, the things we are doubling up on is the little prongy things in the middle? On 28th Aug, 2011 Kean said:
2nd Oct, 2012 at 07:28:12pm
Ahh okay :) Will take a look at this depending on how well the std turbo clutch holds up (its one of those 20% uprated ebay jobbies) Hoping for around 120bhp when its all tuned and sorted so we will see On 10th Mar, 2012 theoneeyedlizard said:
2nd Oct, 2012 at 08:44:20pm
How about Robert????
On 2nd Oct, 2012 deanymini said:
Hi guys. I was wondering if there was anyone on TM that could make me an RTS clutch. Cheers, Adam Best 1/4 mile 13.2 seconds @116 mph
![]() 359 Posts Member #: 8931 Senior Member Herefordshire |
11th Oct, 2012 at 04:45:57pm
I PMed Robert a few months back and he was very helpful and friendly about the situation but was too busy to make one for me. I might have a go myself now :) |
