Home > Help Needed / General Tech Chat > renault t2 oil drain thread
jarmour116
Member #: 10044
Ballymoney, NI
Hi could someone confirm the thread size of the oil drain on a Renault 5 watercooled t2? Looks like 7/8" or m22. Thanks
Do you mean the feed? I though that the drain was a bolt on flange with M6 bolts.
Here is info on the feed
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8057
jarmour116
Member #: 10044
Ballymoney, NI
No I mean the drain. It's a single threaded hole. That's the way it is on the later models
Measure it yourself. TurboDave explains how to quite well here:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4198
Then post up the size for future reference.
Looking at what TD said in the thread linked to, pre GT turbo units used imperial threads. so most likely imperial, but I can't be any more help. all the Garrett turbos I've had used the bolt on flange type drain. Got any photos?
Mike-998
Member #: 9774
Buckinghamshire
I just went to a local hydraulics shop with the turbo and asked if they had anything that would fit.
I didn't end up using the part either, if its any use to you then you can have it?
Edited by Mike-998 on 29th Oct, 2012.
