Home > General Chat > Megajolt leads and USB adapter
Ok, been doing a bit of research on this and with the lack of computer techie understanding, havew come up with conflicting info both on here and on the interweb.
Basically, I need the communication cable and USB adapter to connect the V3 megajolt to the laptop. Where is my best place to get it - not necessarily looking for cheap, just making sure it will work
cheers
Rob
Edited by Rob Gavin on 2nd Nov, 2012.
http://www.diyautotune.com/catalog/usb-to-...atune-p-67.html
sim_ou_nao
Member #: 114
Porto/Portugal
I use one like this
http://www.ebay.co.uk/itm/USB-to-RS232-Cab...=item53ef866820
with this codec
http://www.4shared.com/file/FYcNSTUs/Codec...o_Megajolt.html
works fine for me...
Pedro Silva
Mike-998
Member #: 9774
Buckinghamshire
I bought mine off amazon, worked perfectly
http://www.amazon.co.uk/USB-RS232-Converte...stp_s2_edpp_url
welshdan
Member #: 1111
s wales
Go for trigger wheels rob. Mine worked perfectly as expected, also they are there with almost instant tech support through email. They are a top company
Edited by welshdan on 2nd Nov, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
maplins think its 9.99 with this driver
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=489621
Edited by wng691s clubby on 2nd Nov, 2012.
Done now needs redoing lol
i had 3 ebay ones that wouldnt work then i forked out £20 for the maplins one, the maplins one worked just fine
then so did 2 out of the 3 cheap ones,
most of the time the cheap stuff is ok but the drivers dont work, i just had the same issue with my nissan consult ( early obd style diagnostic port )
Edited by Brett on 2nd Nov, 2012.
Can you download some online drivers? I managed to throw the small cd away!
what he said worked 1st time very happy with it.
Cheers guys, I think I'll go to trigger wheels then
You can if you know what chipset is in the adapter is it just a usb to serial adapter?
If it is try an RS232 driver
Edited by Brett on 3rd Nov, 2012.
Just a standard serial to usb cable.
I Can't understand why they don't do it with usb. No one uses serial any more, I haven't had a laptop with a serial port for over 10 years.
