| Home > Help Needed / General Tech Chat > Mini MPi GT1752 Turbo | |||||||
![]() 7 Posts Member #: 10188 Junior Member |
22nd Nov, 2012 at 09:39:28pm
Hey guys, first post so be gentle (:
869 Posts Member #: 2443 Post Whore Cheshire |
22nd Nov, 2012 at 10:04:16pm
In short .....No. Not unless you bin the rover ECU.
Edited by Andy500 on 22nd Nov, 2012. |
22nd Nov, 2012 at 11:07:54pm
Squeezing more air in will require more fuel. The mpi system isn't up to the job.
In the 13's at last!.. Just |
23rd Nov, 2012 at 07:49:14am
Thanks for the help guys
23rd Nov, 2012 at 10:38:47am
Have a read of this to give you an idea of what is involved.
23rd Nov, 2012 at 11:20:10am
Cheers guys! I tried to use the search before I posted but as you can see I haven't done a very good job of it |
23rd Nov, 2012 at 06:55:00pm
Another quick question whilst the thread is fresh, my MPi radiator fan has packed up recently. Stripped it down but couldn't get it to work. Are there any cheap options that will fit the MPi rad? Replacement MPi fans are rather overpriced.
23rd Nov, 2012 at 07:11:39pm
On 23rd Nov, 2012 Pog_Frog said:
Another quick question whilst the thread is fresh, my MPi radiator fan has packed up recently. Stripped it down but couldn't get it to work. Are there any cheap options that will fit the MPi rad? Replacement MPi fans are rather overpriced. Also was thinking of upgrading the rad when installing a turbo. Do you guys have any front mounted radiators that you would recommend? Cheers fiant cinquento and metro rads have been used a bit |
23rd Nov, 2012 at 07:12:08pm
http://www.twinkam.co.uk/shop/category_7/E...Management.html
23rd Nov, 2012 at 07:20:25pm
On 23rd Nov, 2012 TurboDave16V said:
http://www.twinkam.co.uk/shop/category_7/Engine-Management.html This is a good starting point as well. BTW, the MPi rad is pretty good, why would you want to upgrade? Am I seeing this correctly in that their MPi kit is actually their throttle body injection adapted to the MPI manifold? So that makes it a wet manifold setup? Jean |
23rd Nov, 2012 at 07:32:01pm
the mpi rad is poop. didn't come close to keeping cool on a moderate turbo engine. On 11th Feb, 2015 robert said:
23rd Nov, 2012 at 08:02:47pm
This looks pretty good!
23rd Nov, 2012 at 08:17:01pm
Does anyone know of anybody that has used this kit before for a fi turbo engine? I presume I can just take the air filter off and attach hoses to it to come from the intercooler.
23rd Nov, 2012 at 08:56:13pm
Here we go again, lol
23rd Nov, 2012 at 08:58:12pm
http://www.twinkam.co.uk/shop/category_7/Engine-Management.html This is a good starting point as well. BTW, the MPi rad is pretty good, why would you want to upgrade? Am I seeing this correctly in that their MPi kit is actually their throttle body injection adapted to the MPI manifold? So that makes it a wet manifold setup? Jean Read it again
23rd Nov, 2012 at 10:17:20pm
http://www.twinkam.co.uk/shop/category_7/Engine-Management.html This is a good starting point as well. BTW, the MPi rad is pretty good, why would you want to upgrade? Am I seeing this correctly in that their MPi kit is actually their throttle body injection adapted to the MPI manifold? So that makes it a wet manifold setup? Jean Read it again ![]() I read it again and they actually make it the same as their SPi setup. So it is a wet manifold setup. |
24th Nov, 2012 at 01:15:01am
On 23rd Nov, 2012 apbellamy said:
the mpi rad is poop. didn't come close to keeping cool on a moderate turbo engine. My experience was completely the opposite. So I guess it's 50/50 so far... On 17th Nov, 2014 Tom Fenton said:
24th Nov, 2012 at 09:31:08am
the mpi rad is poop. didn't come close to keeping cool on a moderate turbo engine. My experience was completely the opposite. So I guess it's 50/50 so far... We had one on the upside down skip. It was in the air flow, shrouded and fitted with a big fan. It was OK while you where moving and not driving too vigorously, but thrash it or sit in traffic for a bit and the temp shot up. We fitted a cheepo fiat chinq rad in the end and it was perfect. Edited by apbellamy on 24th Nov, 2012. On 11th Feb, 2015 robert said:
24th Nov, 2012 at 10:38:38am
Taking everyone's points in to consideration I think I will stick with the MPi rad for now and upgrade if necessary. I won't be thrashing the engine too much, just on the odd track day to leave some tuned mk2 golfs in the dust |
