Home > Help Needed / General Tech Chat > Clutch return stop
danb41
Member #: 9285
Oxfordshire
Hi, can anyone tell me what size the gap should be for the return stop on a pre verto clutch set up? I found the diagrams in the haynes, but no specific measurement :/
Dan.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Hi Mate, the way to set the gap is to get some one to hold the clutch pedal to the floor for you, then you wind the inner nut so there is no gap, release the pedal then wind the inner nut in one flat, and lock up with the lock nut.. Alan
Main Build
Upgrade to Turbo
danb41
Member #: 9285
Oxfordshire
Cheers Alan i have already set that, its the little bolt that sits against the clutch arm coming from the wok.
take the spring of on the slave,
pull the lever out by hand, wind the bolt all the way out, then back 1 flat then lock it up and put the spring back.
danb41
Member #: 9285
Oxfordshire
Thanks Joe, same as the throw out adjustment then.
