Home > Technical Chat > Wiring help needed please
Bodge Job
Member #: 953
London
Hi there,
Hope someone can help please ?
I have a 1993 K reg Mini, I had a 1275 engine fitted when I got it and now I have a 998 enging fitted.
The 1275 has a is pre-engaged starter motor and the wiring loom is for that, the 998 uses an inertia starter motor with those small external-type solenoids on the inner wing. I have sorted this all out with the help from this post;
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=486942
I'm still having problems with this set up and I'm not good with wiring. I've got the coil and the dizzy wired up but I dont have a clue whats going on.
I'm not getting any spark from the coil.
Can you please help me ?
Thanks
Bodge Job
Member #: 953
London
Bodge Job
Member #: 953
London
mcalvert39
Member #: 442
Manchester
What voltage are you getting at the + and - on the coil with the ignition on?
Bodge Job
Member #: 953
London
Hi
I don't know how to use the meter thing.
Im not good at wiring, I have power going to both sides of the coil.
Bodge Job
Member #: 953
London
I have one wire (white and yellow) near the solenoid that is not connected to anything.
Wbere does this go please ?
Sorry about the rubbish picture but it can be seen.
Thanks
Edited by Bodge Job on 6th Mar, 2013.
Bodge Job
Member #: 953
London
Bodge Job
Member #: 953
London
Somebody must be able to help me on this ! ?
Please
Edited by Bodge Job on 7th Mar, 2013.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Wiring the ignition should be easy. Basically there should be +12 on the +ve of the coil. The -ve of the coil goes to the points in the distributer. The points ground the coil. When the points open the coil generates the spark to the plugs.
A bit like this:
You should be able to connect it like this outside of the wiring loom, assuming that the +12v is present at the coil during cranking you should then generate a spark.
http://www.twin-turbo.co.uk
ooh that's clever :)
Ben H
Member #: 184
I just googled it, nothing to do with me, but I though it was quite useful.
