| Home > Help Needed / General Tech Chat > Pre-engaged to Inertia starter motor, Wiring help!!! | |||||||
![]() 455 Posts Member #: 953 Senior Member London |
18th Jul, 2012 at 08:25:41pm
Hello,
18th Jul, 2012 at 09:45:26pm
Just swope the flywheels over :) they all fit to the engines the same |
19th Jul, 2012 at 06:27:04am
I agree. Swap the flywheels and starters, simples. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
19th Jul, 2012 at 06:50:36am
what io did in the past was to loop the main feed back tp the big spade connecter on the selonoid, you can use a piece of smaller wire but it worked fine for years,
19th Jul, 2012 at 10:43:01am
I cant go down the Swap the flywheels over road.
19th Jul, 2012 at 10:47:04am
On 19th Jul, 2012 fastcarl said:
what io did in the past was to loop the main feed back tp the big spade connecter on the selonoid, you can use a piece of smaller wire but it worked fine for years, what this does is engage the selonoid and motor together Could you please explain this to me ? How did you do this ? I dont have a solenoid fitted to the inner wing and the starter I'm using is a inertia. Are you saying I should fit a seperate solenoid ? Thanks |
19th Jul, 2012 at 11:03:43am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=369024 If something is worth doing, it's worth doing half of. |
19th Jul, 2012 at 11:05:55am
If you go down this route you will need a seperate wing mounted (high current) solenoid. Best stick with the one Leyland originally used for the inertia starter.
19th Jul, 2012 at 11:10:22am
John, that link is the other way around, converting inertia to pre-engaged.....
19th Jul, 2012 at 02:43:19pm
Buy a solenoid and bolt it to the front subframe, all the original wiring is then within reach of the solenoid. You'll then need a flying lead onto the starter.
19th Jul, 2012 at 02:47:39pm
Have a look on this thread at where my solenoid is http://www.turbominis.co.uk/forums/index.php?p=vt&tid=486617
20th Jul, 2012 at 05:45:41pm
Ok thanks, I think I've got it now, from your help.
23rd Jul, 2012 at 05:33:03pm
Hello again,
On 19th Jul, 2012 Carlzilla said:
Have a look on this thread at where my solenoid is http://www.turbominis.co.uk/forums/index.php?p=vt&tid=486617 Also make sure you have a good earth from car to subframe if you place it there. Found something that will help ![]() |
