Home > Technical Chat > Does your S/Cut box and drops rattle on tick over
mini118118
Member #: 10069
Just wanted your opinions.... do your drop S/cut drop gears rattle on tick over, when you depress the clutch it stops, its a new clutch and bearing, fitted, sounds abit like its not quite out of gear whilst idling..
YES this is normal EDIT: for the sc drop gears, the sc gearset is a little noisey about 5% more than helicals
Edited by BENROSS on 8th May, 2013.
danb41
Member #: 9285
Oxfordshire
Yes, sounds like a bag of nails on idle. But great when giving it some throttle!
yep rattle like fook on idle and scream like fook when i floor it
and i love it! *happy*
Edited by Brett on 8th May, 2013.
My set dont rattle much, they used to be really bad.
It depends alot on the idle characteristics of the cam and the type of flywheel in use.
welshdan
Member #: 1111
s wales
I may also have this 'problem'. Idle is very chattery, it does when clutch pressed. I thought it was the clutch release, put a new one on qnd its the same. So the consensus is that the drops cause this? They are tranx straight cut drops, covered around 1 k miles, but its alway sounded like this. Run an ultralight pre verto setup with phase 2 cam
If the clutch is disengaging properly then it must be somewhere else as they'll be stationary with the clutch in, the vehicle I assume is not moving.
Is it the timing chain rattling or fouling the cover?
Edited by minimole23 on 9th May, 2013.
welshdan
Member #: 1111
s wales
Hi, timing cover modded, so clearence is there. I run a duplex chain, usually tension them but ran without a tensioner this time. It might be that? Have also always had problems with the clutch, changed the lot, cylinders, arms, plate etc etc, its adjusted properly but need to extend the arm a fraction as its still not quite right, pops out of reverse etc
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
welshdan about your reverse gear, the gear its self will not just pop out its a straight cut gear that has next to no side load also it slides into place when in gauged or dis engaged so to me your problem is in the selection mechanism not fully or pulling it out rather than the gear jumping out
welshdan
Member #: 1111
s wales
Hi, didnt expect this to pop up again. Cheers for the reply. I can live with this at the moment, have all new linkage bushes, roll pins etc so will change the lot over winter. If that doest work il be changing the gear linkage itself. On my last gearbox build the selectors looked ok, but did swap them for an almost new set just incase. It made very little or no difference
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
daveg79
Member #: 9579
Tadley, North Hampshire
Certainly noisy! It surprised me, but run in now and performing well. a video of mine for comparison. I asked the same question!
http://youtu.be/d6DHi0xscpk
My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970
that sounded like the fan was catching lol. tbh thats very quiet for sc drops.
yes yes yes straight cut drops give me a semi
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
sounds like the tappets are loudest lol
