Home > Help Needed / General Tech Chat > Thread size for the oil pressure relief valve cap?
tmsmini
Member #: 7637
Fremont California
Any one know the size of the thread for the oil pressure relief valve cap?
I would like to use a mechanical oil temp gauge on an MPi block and the oil temp sensor hole is the same as the oil pressure relief valve hole.
If I am lucky I may be able to find an adapter, if not I will have to drill and tap an old cap to fit the sensor...
Terry
I drilled and tapped an old cap on my car. I'm sure the thread is on here if you search for the thread:
Tada - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=275167
tmsmini
Member #: 7637
Fremont California
I searched as I thought it had been mentioned before. That pic has an arrow but no size for the OPR valve hole maybe I am not seeing the whole image.
From another forum I was told it is a non-standard thread, but it must be known as people make those variable spring rate adapters
Oops... bugger.
KLAS
Member #: 2380
Hamburg, Germany
if i measured correctly its 13/16 with 14 tip
