Home > Help Needed / General Tech Chat > Megajolt laptop/serial connector
bakker110
Member #: 9367
Derby
Right after half a day messing with all the laptops and serial USB adapters I have got I have not managed to install the map on my car. Is there anyone near derby that would be willing to pop over tomorrow morning and upload my map so I can get the car started?
Thanks
sim_ou_nao
Member #: 114
Porto/Portugal
What cable are you using?
Pedro Silva
tadge44
Member #: 2500
Buckinghamshire
The serial to USB adapter is usually the problem, especially if its a cheapie.
I had three and when checked out by the IT manager at the school where I work, he threw two straight in the bin.
wng691s clubby
Member #: 9252
Cleethorpes
try using this driver http://www.turbominis.co.uk/forums/index.php?p=vt&tid=489621
Done now needs redoing lol
bakker110
Member #: 9367
Derby
The drivers are up to date it came with one on a disc and I checked via Internet too!
I think it's also a case that some of the drivers aren't compatible with mj. I have an adapter that works fine, just not with mj. You can get the engine started if you unplug the mj unit and run it on the edis at fixed 10degrees advance.
wng691s clubby
Member #: 9252
Cleethorpes
maplins cheapo lead works 9.99 i think
