Home > Technical Chat > Wilwood Brake Bias whos got one?
I am looking at getting one like the link, so is there anyone running one? and how have you found it?
http://www.merlinmotorsport.co.uk/p3343/WI...def0c740d867cd1
I have a cheep one off ebay and it did not work at all. As it would let the pressure in the line but would not let it out by the looks of it!!
simon.
benjy_18
Member #: 9378
Chobham
You sure you didn't get a line lock by accident? Looked a bit like a line lock tbh
danb41
Member #: 9285
Oxfordshire
I have the same one thats in the link. It's been working fine.
No ben in the end I locked so the rears were not working lol.
So your rears don't lock up at all dan? as mine has burnt a set of rear pads away by the looks of it.
danb41
Member #: 9285
Oxfordshire
I haven't messed with it too much, just guessed where would be ok. The rears don't lock up very easily at all. A bit more fettling would make it even better, just wishing i had mounted in the inside now!
Not a Mini, but I have the older version of that one. No issues.
However, it is annoying that it is just a rotary dial with no clicks, or any way to identify a set position.
For that reason alone I'd be inclined to go fora lever style where there is a positive indicator of position. I think I found cheapish ones on Peter Lloyd's site.
Cant comment on quality of it though.
http://www.ebay.co.uk/itm/BRAKE-BIAS-VALVE...=item41690ed920
nick1275
Member #: 1615
Ferndown, Dorset
I had a lever one and found I couldn't get enough adjustment out of it, got a knob style one which I found had more adjustment
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
ntm1275
Member #: 9395
Or you could try this one
http://www.compbrake.com/bias-valve-withou...ating-type.html
Do you guys use 1/2" cylinders? If not, do so!!
MarkGTT
Member #: 1194
Shropshire.
I have one works great.
t@z
Member #: 452
Chester, UK
si i need one of these so if you can work your magic on a deal for more than 1 then let me know *wink*
www.twitter.com/lilpinkiy
Taz you can have my old one.
You need to remember that the adjustable bias valve doesnt limit the pressure to the rear brakes, it adjusts the point at which the bias goes from 1-1 front-rear split to 3-1 front-rear split. As you screw the adjuster in it brings this point sooner, if you screw it out it makes this point later, so adjusting it wont stop the rears from locking
