Home > Help Needed / General Tech Chat > Bulkhead box dimensions
snowfruit
Member #: 557
Ireland
Could anyone give e the diemsions of the turbo bulkhead box? I seem to remember this being asked on here before, but the search didn't return anything.
The reason I ask is that the cost of a box plus the exchange rate and the postage costs add up to quite a sum when youre buying from Ireland, so I'm thinking of welding one together myself...
try this link it came from the how to section
this should place you in the ball park!
the depth of the box i made mine is 75mm x
Length 370mm dont know the height ! but you can
work it out from the pic
i brought mine down to 1inch off the top of the subframe which gives you a little more clearence
notice the ally spacer inbetween the subframe and the bulkhead
this is bolted through to add some strength back*wink*
http://www.turbominis.co.uk/forums/index.p...t&tid=178&fr=35
Edited by BENROSS on 11th Jul, 2005.
