| Home > Technical Chat > GT1752 Rebuild | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
11th Nov, 2013 at 08:10:06am
Has anyone had the pleasure of rebuilding a GT1752.
11th Nov, 2013 at 09:51:31am
It's really easy. Just remember that the thread that holds the compressor wheel on is left handed.
In the 13's at last!.. Just |
11th Nov, 2013 at 10:17:57am
On 11th Nov, 2013 theoneeyedlizard said:
It's really easy. Just remember that the thread that holds the compressor wheel on is left handed. Definitely have it balanced. I used a GT1752S rebuild kit. It seems to be much better than the standard one. What the mind can conceive the mini can achieve
11th Nov, 2013 at 02:45:04pm
I rebuilt my t3. Wasnt too bad a job at all. I marked the rotating assembly and put it back together as it came apart. Done a few thousand miles on it now, its performed perfectly. Double check the thread though. All over the net it stated that the thread on my t3 was left handed, ot wasnt though. So there could be some variation. Mark it all up, keep it all clean and take your time. It was a satisfying job. Cheers, dan |
11th Nov, 2013 at 03:57:19pm
cheers dan, rebuild kit ordered.
11th Nov, 2013 at 05:13:29pm
Whilst it is sound advice to have the rotating assembly balanced after a rebuild, I have rebuilt two GT1752,s and did not have them balanced - no probs so far.
11th Nov, 2013 at 06:09:02pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=239074 Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Nov, 2013 at 07:35:53pm
Just make sure it all goes back in the same orientation, and you should be fine. I would imagine most turbo rebuild companies wouldn't just balance a turbo someone else has rebuilt, because if it all goes wrong they wouldn't want anyone going back to them passing blame. They may do, just my opinion of what i'd expect them to say. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Nov, 2013 at 09:49:45pm
Marked the comp wheel / nut and shaft.
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
12th Nov, 2013 at 06:34:30am
Lee
12th Nov, 2013 at 07:00:22am
can you show us pictures of the wear you have found compared to a new one lee? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Nov, 2013 at 07:42:15am
Ye will do robert, there is only very slight movement in the turbo.
On 12th Nov, 2013 robert said:
can you show us pictures of the wear you have found compared to a new one lee? oppps sorry, for got all about it. I'll have a look later tonight. On 12th Nov, 2013 Jawd said:
Lee I still need the details off the turbo you are using is it the 185 bhp unit ? Jawd What the mind can conceive the mini can achieve
12th Nov, 2013 at 09:21:25am
did my old t3 with out hastle just needed some tiny c clip plyers
12th Nov, 2013 at 03:58:30pm
The small circlip pliers are needed for the t3, not sure what the setup is on these posh / fancy gt turbos lol! |
12th Nov, 2013 at 04:49:16pm
believe there is a circlip in there somewhere On 12th Nov, 2013 welshdan said:
The small circlip pliers are needed for the t3, not sure what the setup is on these posh / fancy gt turbos lol! What the mind can conceive the mini can achieve
12th Nov, 2013 at 04:50:42pm
i got my pliars off ebay, a set of four for not very much. |
12th Nov, 2013 at 04:52:03pm
i got my pliars off ebay, a set of four for not very much. What the mind can conceive the mini can achieve
usual left hand thread.
