| Home > Help Needed / General Tech Chat > distributor blank dimensions ?? | |||||||
23rd Dec, 2013 at 04:29:03am
so as some know ill not need the dissy due to ms so i need to blank it off only problem is ive forgotten to take the measurements before getting on the plane to see the folks javascript:void(0)
Edited by Turbo This.. on 23rd Dec, 2013. |
23rd Dec, 2013 at 11:21:10am
Thin ice lol On 26th Oct, 2004 TurboDave16v said:
23rd Dec, 2013 at 08:20:44pm
you'll need to call Perry Mason to defend yourself should the owner of the exclusive world wide patent find out you even asked about such an item.
Edited by fastcarl on 23rd Dec, 2013. |
23rd Dec, 2013 at 08:31:40pm
On 23rd Dec, 2013 fastcarl said:
solid water what temperature though :) Yes i moved to the darkside |
23rd Dec, 2013 at 09:35:39pm
solid water what temperature though :) |
23rd Dec, 2013 at 11:13:44pm
i was not where such a part was under such conditions....
24th Dec, 2013 at 08:36:20am
most on this forum use A+ blocks. Therefore the answer you are looking for needs the right person to either know the info off hand, or be bothered to take their hands out the arse end of the turky and get them oily and measure it specifically for you. If I had an A block I would have been kind enough to measure this for you, but I don't.
24th Dec, 2013 at 10:43:00am
ahh i see
24th Dec, 2013 at 10:54:10am
Just find an appropriately sized core plug and bang that in. If something is worth doing, it's worth doing half of. |
174 Posts Member #: 9128 Advanced Member |
24th Dec, 2013 at 11:08:02am
You just need a Ducellier, a hacksaw, suitable tap and bolt. Cut the dizzy just above the flange, knock out the internals. Run a tap down the centre and fit the bolt. |
24th Dec, 2013 at 11:56:20am
Did Ducellier make a distributor for the A Block? On 26th Oct, 2004 TurboDave16v said:
24th Dec, 2013 at 01:00:34pm
considering how cheap they are i would not bother
24th Dec, 2013 at 03:22:01pm
You mean this one Neil? he has an A block On 26th Oct, 2004 TurboDave16v said:
24th Dec, 2013 at 04:32:05pm
On 24th Dec, 2013 Sprocket said:
Did Ducellier make a distributor for the A Block? Thats what I used
24th Dec, 2013 at 09:23:35pm
ahh ive clearly not looked hard enough as the blank i saw was like 40gbp!
976 Posts Member #: 3228 Post Whore North of the Netherlands |
24th Dec, 2013 at 10:01:52pm
most on this forum use A+ blocks. Therefore the answer you are looking for needs the right person to either know the info off hand, or be bothered to take their hands out the arse end of the turky and get them oily and measure it specifically for you. If I had an A block I would have been kind enough to measure this for you, but I don't. The easy option would be to buy one. Also, these 'plugs' started a huge farce a few years back, lol Here is education on why Andy is so keen on his Butt Plugs
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=294437 I measured 26.6mm; that is the hole with the twin threaded hole attachment still in place. Also an A+, this came to 26.4mm is the difference that small? Dazed and Confused.... |
24th Dec, 2013 at 11:08:39pm
Looks like an MRA Minis A+ blank would fit nicely in an A block seeing as it neets a hammer to fit in an A+ block Edited by Sprocket on 24th Dec, 2013. On 26th Oct, 2004 TurboDave16v said:
25th Dec, 2013 at 07:29:57am
personally id be looking to replace the lot to avoid leaks and ease fitment n most important SAVE WEIGHT
25th Dec, 2013 at 08:54:04am
Looks like an MRA Minis A+ blank would fit nicely in an A block seeing as it neets a hammer to fit in an A+ block ![]() Does seem that way.. On 24th Dec, 2013 Sprocket said:
*Edit. Are you suggesting you leave the insert in place on the A block? The plug above replaces the lot. I tried pulling it out, but wasn't able to. TBH as I just popped in to do measure it up I didn't have a thorough look at whether it is possible to get the thingy out. (I did remove the single bolt and was able to rotate it, just couldn't get it out) On 25th Dec, 2013 Turbo This.. said:
personally id be looking to replace the lot to avoid leaks and ease fitment n most important SAVE WEIGHT from looking at the pics the hold down tab looks a different length from a to a+ perhaps thats the difference as surly the rubber o ring can take up a decant amount of hear or there? yo-han did you measure the distance from bolt center line to blank hole center line? Taking it out was my initial thought, just wasn't able to do it easily (as above, didn't change in old clothes). I measured hole diameter. It's a very scruffy looking block in a corner, don't have a distributor for it otherwise I would have measured that up for you. Must be someone on here able to comment on how the get the part out. If you want I can give it another look after Xmas and pull the block out of the corner. Edit: Merry Christmas! Edited by Yo-Han on 25th Dec, 2013. Dazed and Confused.... |
26th Dec, 2013 at 11:18:13pm
thanks for the effort yo han i think ill just buy one seen as they are half what i thought they where
Cheaper still!
