Home > Technical Chat > Lambda & fuel additives
turbosprite
Member #: 9668
Nuneaton
Hi chaps - Dropping NA engine into my Sprite while I rebuild the turbo engine. Spare engine has nice cylinder head (and a few other mods), but is not unleaded converted, so I plan to run with lead replacement additive. As I also want to teach myself needle profiling & tuning with lambda sensor, I was going to practice on this before going to the presumably more tricky turbo setup. Now the question - will the fuel additive affect the accuracy of the lambda sensor? Would it even wreck it??
Thanks!
1971 Austin (Healey) Sprite - running turbocharged since 1993
My Car thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=448825
As long as there is no lead in it, you'll be fine.
but most LRP additives really arent that good. If it's a low mileage vehicle you might be ok for a while though. If you intend to use it, you'd really be best having the head work done
turbosprite
Member #: 9668
Nuneaton
OK, thanks. Will be worth welding a sensor boss into the LCB then. Car does low miles, so VSR shouldn't be too much of an issue in this incarnation
