| Home > Help Needed / General Tech Chat > what drop gears do you use ? | |||||||
57 Posts Member #: 9625 Advanced Member |
4th Jun, 2014 at 07:19:12pm
Hey guys , so i wondering what drop gears people use . ive read through various build threads and i understand people use sc and helical gears , im planning on building a motor making around the 150 mark but i would like to be able cruise at times so was thinking of a 2.9 diff . where is it do you guys get your drops from or out which mini any help would be great guys
4th Jun, 2014 at 07:30:11pm
SC drops are noisey, is short if you are going to use a std helical gearset use SC drops.
4th Jun, 2014 at 07:41:17pm
cheers for the reply benross i was looking at using the clubman gearset tbh
Edited by oliver122 on 4th Jun, 2014. |
4th Jun, 2014 at 08:04:21pm
the prices are roughley the same.
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
4th Jun, 2014 at 08:16:40pm
I've got a 23 tooth primary and 1st motion shaft (1:1), coupled with a clubman sc/cr gear set and its bloody loud. I can be heard from a long way!
5th Jun, 2014 at 05:36:25am
On 4th Jun, 2014 BENROSS said:
the prices are roughley the same. IMO:- better to spend your money on a much better gearset ratio. what would that better ratio be if you dont mind me asking ? |
5th Jun, 2014 at 09:41:27am
For road use minispares clubman gearset is the one to have. |
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
5th Jun, 2014 at 10:18:08am
I use helicals but dont use the car everyday so odds of them losing teeth are slim. F1 cars use helical gears in their gearboxes but I they don't have drop gears which are the weak point Masturbation is not a crime its a hobby |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
5th Jun, 2014 at 11:38:32am
1:1 drop gears and MS clubman SC gearset with 3.2:1 final drive,
5th Jun, 2014 at 12:03:18pm
For a mild turbo road motor I'd go helical 1:1 drops, clubman SC gear set and a 3.2fd. If something is worth doing, it's worth doing half of. |
144 Posts Member #: 10557 Advanced Member |
5th Jun, 2014 at 05:59:19pm
sc drops noisy?.......
Double-Blind experiment, N:
5th Jun, 2014 at 07:13:00pm
Supersonic oil?
5th Jun, 2014 at 07:33:18pm
scamp has MED floating sc drops and normal helical box with xpin diff 3.1
![]() 21 Posts Member #: 9826 Member Essex |
5th Jun, 2014 at 08:20:55pm
Does anyone know if I can rebuild a 1300gt gear set into an a plus case so I can use some a+ drops? As I already have the gear set it would make sense rather than buying a clubman gearset or buying a series drop gears when everything else I have is a+ |
5th Jun, 2014 at 08:24:46pm
So would the 2.9 be to tall then? And the 3.2 better suited , I would like to keep it nippy round town but also be a good cruiser |
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
6th Jun, 2014 at 06:39:31am
I have a 2.9 and ten inch wheels. Sc drops and ST ratio gears, mostly country roads where i live |
6th Jun, 2014 at 10:06:46am
will be but not ran with yet
