| Home > General Chat > What size tap? | |||||||
![]() 15 Posts Member #: 10905 Member Barnsley, whippetshire |
22nd Jul, 2014 at 08:23:09pm
Haven't had time to go in the garage tonight to measure the mini. Does anyone know what size tap is needed to tap a thread in the heater take off hole on a cylinder head? I'm wanting to fit a threaded hose connector but need to order the right size tap ASAP
22nd Jul, 2014 at 08:27:48pm
Haven't ever heard of that being done, why not make or buy a stub for the takeoff? On 26th Jan, 2012 Tom Fenton said:
22nd Jul, 2014 at 08:31:28pm
The previous owner snapped one of the studs then used a cheap stud extractor and snapped that inside the stud so the easiest and quickest fix is to thread the actual take off hole |
22nd Jul, 2014 at 08:37:20pm
What size is the hole? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd Jul, 2014 at 08:47:12pm
I haven't measured it yet, as haven't had time to go in garage tonight, was just seeing if someone knew off hand so I could order the things I need tonight |
22nd Jul, 2014 at 08:57:54pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8886 I have started posting on Instagram also my name on there is turbomk1golf
22nd Jul, 2014 at 09:06:48pm
That's a different hole to the heater take off |
22nd Jul, 2014 at 09:36:32pm
measure the hole first then by the tap that with work with it. On 26th Oct, 2004 TurboDave16v said:
22nd Jul, 2014 at 11:05:48pm
Prety sure 9/16 will do it... but depends how big you drill the hole...
22nd Jul, 2014 at 11:14:49pm
Or put it right and cut the stud extractor out with Dremel and a carbide burr. Edited by PhilR on 22nd Jul, 2014. |
23rd Jul, 2014 at 05:57:39pm
Usually I'd sort things properly but this engine is only a put me on until I build a turbo motor. The hole is 1/2" so what size tap will be needed? |
23rd Jul, 2014 at 06:15:18pm
23rd Jul, 2014 at 07:10:02pm
Depends on what fitting you get hold of... 3/8 BSPT if you want a taper fitting, but you'll need to drill it out to (or close to) 14.75mm |
23rd Jul, 2014 at 07:34:38pm
Iv ordered a m14x1.5 tap and a m14x1.5 hose tail in brass with a 10mm outlet |
23rd Jul, 2014 at 07:35:00pm
Cheers apbellamy |
7th Aug, 2014 at 12:28:27pm
On 23rd Jul, 2014 apbellamy said:
M14 x 1.5 will go down that nicely. |
7th Aug, 2014 at 01:26:51pm
