| Home > Help Needed / General Tech Chat > locking n/a distributor to suit low boost turbo engine | |||||||
40 Posts Member #: 10537 Member |
8th Aug, 2014 at 06:21:19pm
Hello! Right im currently in the mits of converting a 1275 a plus engine into a low boost turbo motor using the gt17 turbo. I woulx like to run around 10psi if not a little more if possible on standard 21268 pistons, as funds are tight id like to use a standard dizzy at the moment till I can afford megajolt setup, ive heard people talk about locking the dizzy at 24-25degrees? Can anyone please explain how I do this? :) ive also thought of using a metro turbo dizzy, would this be a simple change of the dizzy and fine on my set up? Thanks!
8th Aug, 2014 at 06:25:15pm
One thread is enough... On 11th Feb, 2015 robert said:
![]() 1751 Posts Member #: 10190 Post Whore belgium |
8th Aug, 2014 at 06:41:34pm
do understand the responce of apbellamy... i looked into the search function for 10 seconds and came with this answer
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
10th Aug, 2014 at 06:32:20pm
As above, one thread is plenty.
