Home > Help Needed / General Tech Chat > Flow bench anyone use/made one?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
so has anyone got a home built one?
my main concern is getting equal flow and to see that im grinding in a beneficial way lol
im thinking of doing at least a crude one that hopefully shows any difference in flow between cylinders for a given lift during the porting process
ive come across this i think is worth a read if your interested
http://www.dtec.net.au/Flowbench%20Design%20Guide.htm
be good to see what effect my untrained hand has on the head from std form as well as Manny other things along the way like intake plumbing intercoolers air filters etc
i have a large workshop vacuum that i hope will be sufficient for the small mini head if not ill find a way
the part where it gets kinder tricky is the flow plate and having it calibrated to get good numbers
im thinking of punching some holes in an old piston for the vac pole and reading tubes ill then put one or more o rings in place of the rings to seal it up nicely witht he head on a block with a gasket in
the rest of the thing seams simple just the flow plate thingy thats kinder tricky but im sure if i find a guy with a proper flow bench will know how to sort it proppa like
anyways just seeing why ive never herd guys saying things about parts flowing whatever cfm not evan the head guys to me its all a bit of guss work with out any way to read whats hapening
Mike-998
Member #: 9774
Buckinghamshire
Robert built one a few years ago, here's a link:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=468318
Cooper1999
Member #: 6451
South East Northumberland
This is the one I built (but only with two hoover motors):
Sir Yun
Member #: 1592
Smart Guy!
i have one as well ( like robert using a flow quik ).
i have spend a lot of time getting it tweaked and now it is pretty decent . ( as within 1% ) .
for a mini you need something that can measure small differences .
www. flowbenchtech.com will answer most all questions
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Sir, thats brilliant thank you
D4VE
Member #: 10749
lowestoft suffolk
Right had a look at this.. and the link to roberts and i know most tools out there but what the hell is a flow bench!?!?!? Haha
Nothing gets past Dave lol
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
its a way to measure the air volume flowing throw something like a cylinder head or air filter basically anything that has air or similar pass threw it
D4VE
Member #: 10749
lowestoft suffolk
Right ok had a guess it was summin like that, do you have to seal the head up so that all air goes thru just the head? Plus i might sound stupid but surely u dont need something that big to find out air flow?
slater
Member #: 1291
Suffolk / Birmingham
We built one using Flow Quick kit
http://www.audietech.com/
Not had much chance to use it yet but it does work!
