Home > Help Needed / General Tech Chat > piston bore clearance
tony 69
Member #: 10548
chesterfield
Hi fellas I've just had a phone call from the firm boring my engine wants to know what piston bore clearance my engine needs to be. He says the book states 4 thou but he thinks that may be to much and it should be about 2 thou . He wondered if the extra was with it being a turbo can anyone help.
standard block being bored 40 thou not sure what else you boys need to help with the answer
cheers Tony
tony what pistons are they ?
@ 4 thou it will slap its tits off.
mossy2a
Member #: 9751
Derbyshire
Found this
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=509971
I found my notes. I went for 2.5 thou at the piston skirt.
Edited by mossy2a on 14th Jan, 2015.
tony 69
Member #: 10548
chesterfield
Hi ben the piston are omega +40's. i bought a engine in bits with a brand new set of pistons and was told they were +20's so was a wee bit shocked when he told me today they were 40's. I dont have any other info on them and there at the engine builders so cant look for any numbers so hope thats enough.
Cheers david for the info i have read this thread but it didn't seem to come out with a definite answer it was more like 50% for 4 thou and 50% against lol
Cheers Tony
steve1275
Member #: 951
Bromsgrove
My accralites slap like crazy for the first minute or two,then go quiet. Better too loose than too tight.
'Where does the engine go?'
tony 69
Member #: 10548
chesterfield
what did you go for mate 2 or 4 thou
My engine builder did say he though 4 was to much and he said 2 was more realisic he was just worried he was missing something and I suppose also covering his back which you can't blame him for can you
Cheers Tony
Edited by tony 69 on 14th Jan, 2015.
What did the piston manufacture say
I ran 5 though after honing a block out to take standard MT pistons and they ran silently when cold. Obviously less clearance now leaves options to hone out for new rings at a later stage.
tony 69
Member #: 10548
chesterfield
I got them new but second hand with no paper work. I have read that omega don't give out piston bore clearence due to ovaling
tell your pet machinist on those pistons with it been a turbo engine to put 0.002.5" thou "overall" on the skirt clearance and all will be well for many years
tony 69
Member #: 10548
chesterfield
Hi ben is that overall honing incuded
cheers tony
"OVERALL" honing on the diameter of the bore
he will know what you advise him if hese been at it a while, which seems that way on your above post tony.
tony 69
Member #: 10548
chesterfield
Yeh hes been at it a while he was telling me he did lots of these years ago.
Thanks for your help ben i really appreciate it
Tonyy*Clapping**Clapping*
Steve what clearance are you running with those ? in my motor with 73.5 accralites iam running 0.002" and its just super after 5k miles giving it mass! and i mean mass!
on remedial work the pistons, rings and bores were excellent!!!!!!
steve1275
Member #: 951
Bromsgrove
Don't know exactly Steve it was so long ago,but they are about a thou oversize from standard on the bore. Like you I've had these out numerous times with no sign of piston, ring or bore distress. Must have done at least 5000 very hard miles now including a lot of RWYB and much of that with NOS.
