| Home > Help Needed / General Tech Chat > air filter | |||||||
116 Posts Member #: 10945 Advanced Member scarborough/ northyorkshire |
15th Jan, 2015 at 10:57:06pm
is the k n filter rb 0700 big enough for tm running 10 psi, cheers phil |
16th Jan, 2015 at 10:46:07am
I used this cackulation...
16th Jan, 2015 at 12:33:52pm
Given how small filters are in some n/a applications, I'd say it is more than adequate for a turbo mini install.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
12th Jan, 2016 at 07:03:55pm
Hey all... im wanting to replace the k+n filter as its probably 6/7000 miles old now and sucked in and mishaped..
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
12th Jan, 2016 at 08:05:28pm
http://minispares.com/product/Classic/Filt...ack%20to%20shop this is what I have, running 10psi on it perfectly fine. They don't die, they just get faster! |
12th Jan, 2016 at 08:23:33pm
On 12th Jan, 2016 Shauna said:
http://minispares.com/product/Classic/Filters/Air/RU-0840.aspx?1201&ReturnUrl=/shop/classic/Filters/Air.aspx|Back%20to%20shop this is what I have, running 10psi on it perfectly fine. Same as what I run fine well above 10psi I have started posting on Instagram also my name on there is turbomk1golf
13th Jan, 2016 at 07:20:08am
I use this one.
13th Jan, 2016 at 11:47:33am
What size have you got? I'd love it if I could get away with a smaller one!
13th Jan, 2016 at 11:50:36am
70mm inlet. Its quite small but should be ok. I haven't done any calculations.
13th Jan, 2016 at 12:46:09pm
Does it have the extra guaze that people have mentioned about needed for turbo use? On 24th Oct, 2015 jonny f said:
13th Jan, 2016 at 01:11:43pm
No idea Dave. |
13th Jan, 2016 at 05:32:13pm
Why do you need extra gauze for turbo use? It's not like the turbo creates a huge vacuum on the inlet side. |
13th Jan, 2016 at 05:48:37pm
On 12th Jan, 2016 D4VE said:
Hey all... im wanting to replace the k+n filter as its probably 6/7000 miles old now and sucked in and mishaped.. That doesn't sound good, what one did you have Dave? |
13th Jan, 2016 at 06:06:12pm
Looks like the minispares one above.. its not too bad its just the fins etc.. just thought a fresh one would be best rather than try cleaning it..
13th Jan, 2016 at 07:51:34pm
Soon find out ay :). |
![]() 428 Posts Member #: 10128 Senior Member Dorset |
14th Jan, 2016 at 12:32:46pm
Mine's the same K&N as Shauna linked. Like Dave, mine has got a bit battered through multiple fittings but has also sucked the top inward during the last few months of aggressive use!
14th Jan, 2016 at 12:43:02pm
Ive got a tiny one off a Corsa. Good for 200hp, no idea how well it filters. In the 13's at last!.. Just |
14th Jan, 2016 at 01:50:56pm
Yup.. looks like that but not that much of a dip in the top haha but beat up n dirty like that
On 14th Jan, 2016 e5tus said:
Mine's the same K&N as Shauna linked. Like Dave, mine has got a bit battered through multiple fittings but has also sucked the top inward during the last few months of aggressive use! ![]() On 24th Oct, 2015 jonny f said:
14th Jan, 2016 at 04:31:09pm
Is that filter as filthy as it appears to be in the photo? If it can't flow air it will end up creating a depression in the filter and ducting. |
14th Jan, 2016 at 04:40:12pm
Where are you mounting them - do you put shrouding around any side that directly faces the incoming air so they don't get blasted with crud? |
14th Jan, 2016 at 05:56:49pm
Mines pretty much sitting on the bulkhead atm, it doesn't fit anywhere else without being in the way of something else (hence wanting a smaller one if I can) I think it's been cleaned twice in a year and a half. It's never got nowhere near as dirty as the e5tus has posted and my engine bay doesn't stay clean for long after I spent hours decruding it! I thought the whole selling point with k&n was that you clean them rather than throw them away and buy another? They don't die, they just get faster! |
14th Jan, 2016 at 07:04:55pm
Whats best to clean them with?
14th Jan, 2016 at 08:00:54pm
There's kits like this for them, pretty sure euro car parts and places like that sell cleaner and oil for them too :) mines in the same place, we relocated my washer bottle to fit it there haha
On 14th Jan, 2016 D4VE said:
Whats best to clean them with? Mine is vertically up from the turbo between the plenum and the wiper motor.. if that makes sense? Edited by Shauna on 14th Jan, 2016. They don't die, they just get faster! |
14th Jan, 2016 at 08:34:05pm
Mine's the same K&N as Shauna linked. Like Dave, mine has got a bit battered through multiple fittings but has also sucked the top inward during the last few months of aggressive use! ![]() Where is the filter located ? Excessive heat can cause the rubber to go soft and lose its shape. Why the filters buckle like that no idea, but seen loads like it and I dont believe for one second it's because the engine is pulling too much air. 9.85 @ 145mph
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
15th Jan, 2016 at 03:45:09am
I'm having big trouble trying to get some pipe/hosing on to the turbo.. The space is way too tight to get anything to bend nicely through 90 degrees. The wastegate is making it awkward but the main problem is the bottom hose, it's fecking near on impossible... I bought some 60mm silver flexible hose but that got mangled just trying to attach it. I was thinking about something less delicate like some rubber hose but the space won't allow anything in there without it kinked/crushed slightly... Any suggestions? Sorry for the hijack... |
