| Home > Help Needed / General Tech Chat > Which turbo? | |||||||
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
29th Aug, 2005 at 12:10:41am
Which turbo, carb, manifold is best to use on a 1293cc? |
29th Aug, 2005 at 07:58:57am
the garret T3 fitted to the mg metro turbo is in my oppinion far too LARGE!
29th Aug, 2005 at 09:04:16am
cheers for that anymore advise?
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
29th Aug, 2005 at 02:08:43pm
think that says it all bud. avonbar do the best bulkhead boxes, you can make ure own but why bother its more hassle than its worth. as for t3 i have had no issues with this turbo, so if you want to avoid expense in the t2 conversion then this one is ok, most of the folks are running this "spooler" it all depends on what you want mate. you need to have a clear objective before plunging into the build / buy. what sort of Hp you want, what budget etc etc. the only advice i would be able to add to Bens is if you buy 2nd hand (which you probably will unless u is minted) strip and rebuild prior to putting into the car !! otherwise you will be pulling engines out and getting pissed off. my other advise is be neurotic like moi ! then you will probably make sure the engine is sweet before it goes in lol !
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
29th Aug, 2005 at 03:40:49pm
First time into turbo minis? Slightly limited knowledge / experience / facilities?
208 Posts Member #: 438 Senior Member London |
29th Aug, 2005 at 04:22:29pm
I've got a bulkhead conversion box, brand new, never used (got a mirage kit).
29th Aug, 2005 at 10:22:32pm
thanks again pm sent!!
29th Aug, 2005 at 10:30:18pm
daa daa http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5742
31st Aug, 2005 at 05:51:10pm
looking at it from turbo daves point
244 Posts Member #: 34 Senior Member |
8th Sep, 2005 at 11:17:02pm
I fully agree that the T3 is the best way to start on your first turbo conversion.
