Page: |
Home > A-Series EFI / Injection > New to EFI conversion | |||||||
307 Posts Member #: 11231 Senior Member |
26th Jan, 2016 at 11:34:09am
What is the reason of the swap of the idle air control valve ? And what if I don't use one at all ? I have seen engines in the past using EFI with no idle air control. |
26th Jan, 2016 at 12:17:45pm
The MS3 is designed to be used with a bi-polar stepper motor and has all the circuitry included as standard. The Rover valve is uni-polar. Page 45 of the MS3 manual has more info.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
26th Jan, 2016 at 09:15:23pm
You still need the TPS for Acceleration enrichments even when you use the MAP sensor On 26th Oct, 2004 TurboDave16v said:
26th Jan, 2016 at 09:22:13pm
On 26th Jan, 2016 Barrieri said:
What is the reason of the swap of the idle air control valve ? And what if I don't use one at all ? I have seen engines in the past using EFI with no idle air control. I ran the 16v engine without IAC and it was horrible when cold. As Paul suggests it will work without it, however, there is no compensation for lack of air on warm up. If you already have the hardware, why would you not use it? In my opinion, the whole point of EFi is to gain more control, not less. There are other benefits with IAC, not just warm up. On 26th Oct, 2004 TurboDave16v said:
27th Jan, 2016 at 04:59:35pm
You're right mate I will eventually. I will begin the build in a short while |
30th Jan, 2016 at 09:43:18am
Hey guys, regarding fuel pump and filters, are there any specific I should use ? |
20th Feb, 2016 at 11:02:24pm
What is the flow rate of the stock mpi injectors ? at 3 bar |
21st Feb, 2016 at 12:27:50am
About 480cc/minute Edited by Sprocket on 21st Feb, 2016. On 26th Oct, 2004 TurboDave16v said:
21st Feb, 2016 at 08:03:24pm
Sooo finally my 998cc has started with ms3x :) However it seems that I have an air leak from between the MPI intake manifold and cylinder head. The manifold flanges seems to be slightly arched and thus are letting air in. I'll try to get that fixed up.
967 Posts Member #: 3228 Post Whore North of the Netherlands |
25th Feb, 2016 at 10:03:38am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=526218
Dazed and Confused.... |
26th Mar, 2016 at 09:04:26am
Hey guys, today I will be giving another try on the Mini Injection Setup. I have everything wired up, just a few bits and pieces left, but I will take care of it today and later I will try to start up.
Edited by Barrieri on 26th Mar, 2016. |
26th Mar, 2016 at 09:19:10am
Also I have a coil pack as per attached |
26th Mar, 2016 at 06:05:59pm
On 26th Mar, 2016 Barrieri said:
In particular, what spark and injector channels should I be using on the ms3x ? Is there a particular two channels which I should use ? Simplest setup to get it running is to use injector channels A & C. Use twice the engine capacity for the REQ_FUEL calculation as you are only using two of the four injector outputs. With the logic level coil pack pictured you will need to wire it up for wasted spark as shown in the diagram. In Tuner Studio select MS3X outputs and wasted spark. Edited by Paul S on 26th Mar, 2016. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Mar, 2016 at 07:57:09am
Thanks Paul. I'm currently using injector channels A and B. Why exactly do you use channel C ? Because of the output phasing between the channels ?
27th Mar, 2016 at 11:39:00am
As the ports operate 360 degrees apart then you need two channels, 360 degrees apart, so A & C are required.
27th Mar, 2016 at 11:45:44am
So then I guess that I should set the spark on channels A and C as well ? Right ?
27th Mar, 2016 at 11:47:44am
On 27th Mar, 2016 Barrieri said:
So then I guess that I should set the spark on channels A and C as well ? Right ? No, spark is A & B. I think that is the case, only I've never used wasted spark with the MS3X. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Mar, 2016 at 11:49:41am
Hmm ok... that should prove to be a problem for me. Yesterday I was trying to use spark A and B but for some odd reason from channel B there was no output. Then I changed channel B with C and started correctly. I don't know whats up with channel B. |
27th Mar, 2016 at 11:55:56am
Hmm ok... that should prove to be a problem for me. Yesterday I was trying to use spark A and B but for some odd reason from channel B there was no output. Then I changed channel B with C and started correctly. I don't know whats up with channel B. It's probably a setup issue. If A&C spark work then stick with it. You're the first on here to try wasted spark on the MS3X so you are breaking new ground. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Mar, 2016 at 11:59:52am
I'll keep you updated on that then. |
27th Mar, 2016 at 12:53:50pm
We are running the standard MPi injectors on our 998. The Required Fuel value is 8.5mS.
27th Mar, 2016 at 01:12:38pm
So then I must be doing something wrong. Attached is my setup. My required fuel is 16.2ms if I put 998cc as engine size. If I double it, it comes even larger. The car is running very rich, almost 10AFR.
27th Mar, 2016 at 01:34:57pm
You should be using Speed-Density not Alpha-N.
27th Mar, 2016 at 01:50:28pm
Once you told me that in sequential mode, you can do with making the ECU squirt one long pulse instead of spraying twice the same injector consecutively. Do you impose that to the ECU in the above tab by "1 squirt per engine cycle" and "simultaneous" ? |
27th Mar, 2016 at 02:00:32pm
This is the method to apply one single squirt to fill 2 cylinders.
Page: |
